Thanks Thanks:  3
Thread: Spanner Wrench Fit For Koni Coil Overs?
    Jul 2024
    BC, Canada
    Can anyone share a specific wrench that fits the Koni's?
    I have two, one of which is adjustable, however neither fit
    I got this one from Speedway Motors that works fine on my RED-KONI's.
    https://www.speedwaymotors.com/Speed...Tool,2681.html
    Have A Happy Hanukkah & Merry Christmas!
    Hope This Helps!
  3. Thanks Doc76 thanked for this post
    O'Fallon, MO
    NON are needed. You adjust them with the spring tension OFF
    Jun 2015
    Fairfax Station VA
    As Rich says, a wrench is generally not needed. But one time I had a shock sag enough that I needed the wrench to get back to ride height.
    A Williams 0-472 works perfectly. I got mine from Mark Reynolds at Breeze.
    MK IV Roadster #8631
  6. Thanks Doc76 thanked for this post
  7. #5
    Looks similar to what I bought. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    My rings were stubborn, even unloaded, and this tool worked perfectly to get them to turn without damaging anything.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Member of the The Gateway Cobra Club
  8. Likes Doc76 liked this post
  9. #6
    Dec 2017
    Southern Ontario/Cape Coral FL
    Definitely take the load off the springs but if they are still a little stubborn, stick the short end of an Allen key in the hole and give'r a tug.
    Higgy
    MK4#? Ordered 11/30/24
    MK4 #11012 picked up 04/16/24
  10. Thanks Doc76 thanked for this post
  11. #7
    Jul 2024
    BC, Canada
    Thanks guys
    Yup I have a couple that are stubborn. Is there a rule of thumb with a Ford 8.8 solid rear with front FFR suspension that can be kept in mind one can expect to see for turns of the nut vs height?
    Ie, 1 full turn should see 1/8” rise or drop, etc.
    Cheers
  12. #8
    Bourne-Cape Cod, MA
    Factory Five has provided one with their kits for years. It is a bare metal thing with a tab on it, and hole on one end. It doubles as a Rivnut setter. I know this sounds goofy., but it is actually true.
    FFinisher/AKA RE63
