Hi, I searched the forum and couldn't find an answer to my question. Did Factory Five change the hazard switch at some point? The supplied switch has 6 (1/4") terminals however the Ron Francis harness is supplied with 1/8" quick connect terminals. I saw post from 2019 with a switch that appears to have 1/8" terminals on the hazard switch.
Trying to make sure I am using the correct switch.
thats the correct new switch. Its better with the bigger connections. Put the pinks on one end and put the other 2 in the center. This prevents the open terminals from being live when the hazards are off.
