Thanks Thanks:  3
Results 1 to 8 of 8
Thread: Spanner Wrench Fit For Koni Coil Overs?
    Jul 2024
    BC, Canada
    Can anyone share a specific wrench that fits the Koni's?
    I have two, one of which is adjustable, however neither fit
    I got this one from Speedway Motors that works fine on my RED-KONI's.
    https://www.speedwaymotors.com/Speed...Tool,2681.html
    Have A Happy Hanukkah & Merry Christmas!
    Hope This Helps!
  3. Thanks Doc76 thanked for this post
    NON are needed. You adjust them with the spring tension OFF
    Fairfax Station VA
    As Rich says, a wrench is generally not needed. But one time I had a shock sag enough that I needed the wrench to get back to ride height.
    A Williams 0-472 works perfectly. I got mine from Mark Reynolds at Breeze.
    MK IV Roadster #8631
  6. Thanks Doc76 thanked for this post
  7. #5
    Looks similar to what I bought. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    My rings were stubborn, even unloaded, and this tool worked perfectly to get them to turn without damaging anything.
  8. Likes Doc76 liked this post
  9. #6
    Southern Ontario/Cape Coral FL
    Definitely take the load off the springs but if they are still a little stubborn, stick the short end of an Allen key in the hole and give'r a tug.
    Higgy
    MK4#? Ordered 11/30/24
    MK4 #11012 picked up 04/16/24
    MK4 #10616 picked up 4/10/23 SOLD
    MK4 #9759 picked up 4/3/19 SOLD
  10. Thanks Doc76 thanked for this post
  11. #7
    Jul 2024
    BC, Canada
    Thanks guys
    Yup I have a couple that are stubborn. Is there a rule of thumb with a Ford 8.8 solid rear with front FFR suspension that can be kept in mind one can expect to see for turns of the nut vs height?
    Ie, 1 full turn should see 1/8” rise or drop, etc.
    Cheers
  12. #8
    Bourne-Cape Cod, MA
    Factory Five has provided one with their kits for years. It is a bare metal thing with a tab on it, and hole on one end. It doubles as a Rivnut setter. I know this sounds goofy., but it is actually true.
    FFinisher/AKA RE63
