Likes Likes:  2
Results 1 to 21 of 21
Thread: Stubborn Brake Fluid Air Pocket?
    Jun 2023
    Texas Hill Country
    Build Friends,
    These pics show what looks like a stubborn brake fluid air bubble in the remote reservoir adapter at the master cylinder tops. The brakes have been bled manually one corner at a time and the pedal is firm. This “bubble” expands/moves when brakes are applied. The reservoir fluid level is above the MCs but the feed hose from reservoir to MC adapter is level with or just below the MC at times as it travels through the footbox front.
    Parts:
    Tilton 75-750 with remote adapter
    FFR fluid reservoirs with 1/8NPT to 5/16 barb fitting
    5/16” hose from reservoir to MC adapter
    3AN male to 3AN male
    3AN Brake fittings/lines
    The previous Wilwood MC had black remote adapters so it may have had the same pocket and I wouldn’t know it.
    The air pockets have been there a week and I re-bled the corners yesterday and they remain. While the brakes feel good now, it seems during handling forces the bubble could move and get “sucked” into the cylinder.
    Is it time for a pressure bleed?
    BUDFIVE
    Complete kit order 8/28/2023
    347 Ford Dyno 10/12/2023
    Kit Delivery 11/28/2023
    First Start 7/4/2024
    Go Cart 8/31/2024
    O'Fallon, MO
    It isn't a problem
    Rich please explain that.
    O'Fallon, MO
    The pocket is above the fluid, no different that a reservoir attached directly to the MC. Fluid is drawn in from the bottom of the fluid reservoir when the MC is retracted, that port closes when you apply the brakes.
    Dec 2021
    Marietta, GA
    Agree, it won't get 'sucked' into the MC. The air will want to float to/ stay at the top. Mine are black, I wouldn't ever know if I had a bubble in there.
    Mk4 Roadster complete kit Chassis F5R1010480RD
    Ordered Dec 2021, Delivered Sept 2022, First start Mar 2023
    Completed October 2023
    IRS, Wilwood, 17" wheels, Forte 427W/TKX/EdelbrockEFI
    Aug 2021
    Rich is right but perhaps also leave the reservoir fluid cap very loose overnight to let the bubble rise naturally?
    Ray
    Jun 2023
    Texas Hill Country
    Guys thanks. Ray, I too thought about leaving the reservoir unsealed. It looks like it might help if I raised the front vs rear of the car.
    BUDFIVE
    Go Cart 8/31/2024
    You might need to pull a vacuum to get rid of the air pocket.
    O'Fallon, MO
    Leaving the top off the reservoir might not be a good idea as brake fluid easily absorbs moisture?
    I would just leave it alone
    Senior Member Bill Elliott's Avatar
    Jan 2023
    Woodway, TX
    Rich is correct, exposure to air degrades the quality of the fluid . The absorbion of moisture reduces the boiling point of the fluid. You would have more problems later bigger than that bubble sitting on top of the fluid.
    Delivery Date 6-24-23 Build thread Living the Dream
    SBF 427 564hp/576tq Holley Sniper with Hyperspark by Smeding Performance. Tremec TKX .68 OD. IRS . Wilwood 12.88 brakes. Wilwood EPB. First start 11-17-23. First go cart 11-20-23.
    Jun 2023
    Texas Hill Country
    Great discussion with lots of knowledge bits.
    Rich, good point about moisture.
    Michael, vacuum at the calipers? If so that should be the same as pressure at MC?
    Bill, aside from trying vacuum or pressure, doing nothing might be the right thing.
    BUDFIVE
    Go Cart 8/31/2024
    i.e.427's Avatar
    Nov 2016
    "The i.e." SoCal
    One tip to avoid this from happening is to elevate the reservoirs during the initial bleeding. I struggled with a Mk4 over the weekend that just wouldn't bleed. I finally loosened the reservoir from it's mount and held it up while bleeding and it started moving fluid.
    Jun 2023
    Texas Hill Country
    Thanks Frank,
    I moved the reservoirs to the highest position in the mounts but didn’t try pulling them down, out of the mounts and holding them above the frame rail. Good to know.
    BUDFIVE
    Go Cart 8/31/2024
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    I must have burned thru an entire quart of brake fluid doing my system. I got it, but made quite a mess in the process killing air bubbles and moving reservoirs and whatnot.
    Matt
    My build thread here
    If you need to move the reservoirs from their standard mount position isn't that telling you that you need to move them permanently?
    Jun 2023
    Texas Hill Country
    CraigS-interesting thought. I hope once there is no air between the reservoir and MC the fluid has inertia to stay there.
    My read on moving (raising) the reservoirs during bleeding is to provide enough gravity force to overcome the fluid’s inertia, getting it to flow from the reservoir to the master cylinder replacing the air already there. That inertia could be surface tension, short rises in the hose, hose ID vs fluid viscosity, etc. I believe my problem is only there because the air is between the reservoir and top of MC, above the force created pumping the brakes. In fact, as I think about this more, bleeding with the reservoir cap on loosely vs off may not be helping me. I think the force can also be pressure at the reservoir. So if I need to I’ll try pressure bleeding because the air pockets bother me
    “……an object at rest, tends to stay at rest; an object in motion tends to remain in motion…”
    BUDFIVE
    Go Cart 8/31/2024
    cv2065's Avatar
    Dec 2017
    Use an air bleeder. This thing is amazing. 5 minutes a corner.
    https://www.harborfreight.com/pneuma...kit-57057.html
    Member Wizbangdoodle's Avatar
    Nov 2023
    I concur with Rich, not a problem. The only air that will be a problem is when it enters the pressurized section of the brakes, i.e. the piston section of the MC. Think of a typical master cylinder on an old car or truck. You fill it up and then place the cap on and pull the retaining bar over the top to keep it in place. There's a bunch of air between that cap and the brake fluid. Same thing here. As long as you don't drive upside down, you'll be fine. This truly is a non-problem.
    i.e.427's Avatar
    Nov 2016
    "The i.e." SoCal
    The short answer is yes. Ideally the entire supply hose and reservoir would be higher than the masters. However, with the platforms we are dealing with, this isn't possible. With the donor master cylinder and remote reservoir, this wasn't an issue. The reservoir was higher than the master. With the Wilwood's/Tilton's it's not. My recommendation is to raise the reservoirs during initial bleeding, so that any air pre-master can migrate up and out. The question was about an air pocket pre-master but post-reservoir and is it a "problem"? For now.......... no problem. I am not a fluid dynamics engineer. I have however been in the electrical field for some time. And I can tell you, they call it electrical theory for a reason. It doesn't always do what you think it's going to do, or what it's "supposed" to. I always raise the reservoirs during the initial bleeding in a Mk4 or Coupe. It's just become habit.
    You all do you.
    Jun 2023
    Texas Hill Country
    Hey y’all—I wanted to share this follow-up:
    I tried re-bleeding the brakes this week with the reservoirs removed from the mounts and raised as high as the hoses would allow—the air pockets remained. I then tried pressure bleeding-the air pockets remained. With the general consensus it wasn’t an issue, I put this on the back burner. In my build thread update tonight I mentioned that during my 2nd golfcart the pockets disappeared—apparently the drive vibration and repeated, firm brake application bubbled the air up into the reservoirs. The brakes felt and performed great today. Thanks guys.
    BUDFIVE
    Go Cart 8/31/2024
  21. Likes danmas, BornWestUSA liked this post
  22. #21
    Glad it worked out for you. Nice not to have your brain saying, 'You sure it will be OK?'
