Thanks Thanks:  5
Likes Likes:  3
Thread: Upper Steering Column Spring Washers
    Jul 2024
    BC, Canada
    Anyone happen to have a picture of the titled part?
    The two parts are missing from my column.
    I need to source a few. FFR didn't have an image or any details on this part and I want to make sure I get the correct style. Seems to be several types of 1/4" spring washers, various thicknesses and bend-types.
    I dont use them. Drill and tap a couple of 1/4-20 or equivalent Holes a few inches apart on the same side of the outer tube. Slide the inner shaft where you want it and then lightly tighten the screws with some red loctite on them. Tighten them just enough to take the wiggle out but still able to collapse.
  3. Thanks Doc76 thanked for this post
    Likes Nigel Allen liked this post
  5. Thanks Doc76 thanked for this post
  6. #4
    Aug 2012
    Grand Rapids, MI
    I like Mike's solution.
    Might suggest flat point set screws in 1/4-28 thread, the outer sleeve isn't that thick, and the finer threads provides a higher thread count. The flat points wouldn't bite in the way a cup point would.
    Jim
  7. Thanks Doc76 thanked for this post
  8. #5
    Mar 2024
    born in San Jose, CA and lived mostly in Santa Cruz. Just married again in '22 and in Junction City.
    As most may know, McMaster-Carr has one of the most extensive hardware catalogs with quick shipping and reasonable pricing (in my experience).
    ALSO, they have a VERY impressive search feature in their HW listings. I wish others would copy/steal it!
    Here's a link, just btw, for something similar to what Jeff K. posted:
    https://www.mcmaster.com/products/st...rs/springs-1~/
  9. Likes Doc76 liked this post
  10. #6
    I also went the bolt/nut route. I first used a G8 pair and tightened it as tight as I could so I would collapse the outer shaft. Then I pulled the G8 stuff and replaced it w/ standard hardware store stuff.
  11. #7
    Senior Member mrglaeser's Avatar
    Jan 2020
    Twin Cities, MN
    If you want to go with the spring washers still, I had to replace mine. Here is an older forum post with the McMaster-Carr part number, the number, and a link
    https://thefactoryfiveforum.com/arch...p/t-26484.html
    Part Number 9712K62
    https://www.mcmaster.com/catalog/130/1538/9712K62
    I ordered the replacements and they worked fine, plus now I have a couple spares. They come in a pack of 12 for $6.50 plus shipping.
    Mark IV, 302 Based 347, TKx, Four link w/3.55, coil overs, PS, 4wheel Willwood. Dark Blue w Black/Red stripes, Saddle Interior, Blacked out chrome.
    Kit Ordered 4/18/2022
    Kit Delivered 2/20/2023
    Engine Install 9/15/2024
  12. Thanks Doc76 thanked for this post
  13. #8
    Member BornWestUSA's Avatar
    Jul 2022
    Ventura County, CA
    1 9712K62 Belleville Disc Spring for 1/4" Shaft Diameter, 0.255" ID, 0.5" OD, 0.0220" Thick, Packs of 12
    That is the McMaster ones I used, better than it was, but still not "tight", you can feel some slop between the two components.
    Mk4 Roadster #7945, Ford Racing 427W, Quick Fuel 850, TKO600, 3 Link, One of Jeff Miller's last paint jobs. California SB100 completed June 2024
  14. Thanks Doc76 thanked for this post
  15. #9
    Jul 2024
    BC, Canada
    Thanks guys
    Anything will be better than the corner cut to put mine together as you can see from the little shim sticking out I can grab and pull out.
