Thanks Thanks:  18
Likes Likes:  36
Page 3 of 3 FirstFirst 123
Results 81 to 106 of 106
Thread: MJS Coupe Build
    Dec 2018
    Hudsonville, MI
    Coupe Kit Delivered 11/10/23
  2. Likes 460.465USMC liked this post
  3. #82
    Dec 2018
    Hudsonville, MI
    Other projects done! Time to get back after the coupe. Spending some time re-acquainting with the next steps and planning. Excited to get back to it.
  4. #83
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    More important projects than a second toy car?! Blasphemy
    Ordered: 2/14/2024
    Received: 5/24/2024
  5. #84
    Dec 2018
    Hudsonville, MI
    Quote Originally Posted by JimStone View Post
    Valid point
  6. #85
    Senior Member PNWTim's Avatar
    Aug 2024
    Damascus OR USA
    Agreed
    Coupe complete kit ordered: 9/26/24. Gen 4 Coyote. T-56. IRS w/3.73. Wilwoods. PS. HVAC. Side windows.
  7. #86
    Dec 2018
    Hudsonville, MI
    Brake line routing question. Future problem with interference or no problem? Accidentally went in back of the square bar.
  8. #87
    Senior Member Kbl7td's Avatar
    Apr 2022
    Miami
    That’s where i went, you’ll just have to notch the panel that fits up there.
  9. Thanks MSumners thanked for this post
  10. #88
    Nov 2022
    Niles, MI
    I did the same. If you go in front of the square frame then you're into the engine bay. Plus, I blindly follow Paul and that's where he ran everything through (brake line, HTB line, electrical)
    Ordered: 2/14/2024
    Received: 5/24/2024
  11. Thanks MSumners thanked for this post
  12. #89
    Dec 2018
    Hudsonville, MI
    I could make a trash-metal tyrannosaurus from the brake line error pieces I’m collecting.
  13. Likes PNWTim, 460.465USMC liked this post
  14. #90
    Dec 2018
    Hudsonville, MI
    I'm at the point in the instructions where it's time for drivetrain install. I did finish the brakes beforehand just because I thought it would be easier.
    Any other things recommended to do out of order and get done before drivetrain install, coyote specifically?
  15. #91
    Dec 2018
    Hudsonville, MI
    Coyote ready to go home
  16. Likes 460.465USMC liked this post
  17. #92
    Dec 2018
    Hudsonville, MI
    Dropped the coyote in today. Went slow and no real issues.
    Question for those with the 6 speed magnum and coyote. How exactly does the Tran’s mount plate fit? Even with no spacer under the poly mount there isn’t enough room, even with the trans jacked up touching the tunnel top bars. The engine mounts are squared seated.
  18. #93
    I don't remember every specific detail, but my build with the T-56 and Coyote also pushed the shifter against the underside of the transmission tunnel. I ended up with the mounting plate under the chassis tabs. As I recall, had to trim the mounting plate just slightly to fit there. Worked OK from there.
  19. #94
    Dec 2018
    Hudsonville, MI
    Perfect, thanks! Agreed the plate will have to be trimmed some but not bad to fit from underneath. Wanted to make sure I wasn’t missing something!
  20. #95
    Dec 2018
    Hudsonville, MI
    Holiday baking
  21. Likes PNWTim liked this post
  22. #96
    Dec 2018
    Hudsonville, MI
    The engine I ordered came with a power steering pump but appears non adjustable, as far as I can tell. I think I would need to add a heidts valve?
    I also actually have the KRC system as I planned poorly and ordered it from factory five. Is it easy to switch out? I really like the adjustable valve on the roadster and already know how I would set it up so leaning that way. Any thoughts appreciated
  23. #97
    I am a fan of the KRC setup for the Coyote. I've used it twice and they've been flawless. May not make a difference in a regular street driven build. But I'm convinced their in-house produced pumps are superior to the usual OE pump. The built-in reservoir makes plumbing easy. Plus with the changeable spool valves, you can adjust the boost pretty easily. Only disadvantage would be not able to change it on the fly like with a Heidts valve, e.g. one setting for the street and one for the track or auto-x. This is a picture of the KRC setup on my Coupe build including with an A/C compressor. I'm not positive the pulleys and serpentine setup are exactly what you already have. Could be more than just changing the A/C pump.
  24. #98
    Dec 2018
    Hudsonville, MI
    Thanks! I think for now I’ll stick with the current setup and add the heidts valve. I think if I try to figure out the switch it may (definitely) lead to misordered parts and replacing more than I’d like. A bit more reading to do though.
  25. #99
    Dec 2018
    Hudsonville, MI
    Spent half the day thinking I was a crazy person, or maybe just crazier. I went to mount the coyote headers and the bolts wouldn’t easily start by hand. Did some reading, verified the right spec and pitch , checked the box. Then finally checked the actual bolt and realized the stage 8 box is mis-labeled. Calls out fine pitch 1.25 but is actually course 1.5.
    Hopefully stage 8 or FFR will exchange, I’m confident they will if history is any guide.
  26. #100
    Aug 2024
    Damascus OR USA
    Always nice to gaslight yourself with mislabeled parts! At least you figured it out before they went sailing out the garage door.
  27. Likes MSumners liked this post
  28. #101
    Dec 2018
    Hudsonville, MI
    Interesting thread issues lately.
    This looks like 10-32 but isn’t. Nor an m5. Actually can’t get anything on my thread checker to start.
    Anyone recall or know what thread this is supposed to be.
    Otherwise no problem I’ll just drill and re-tap, just found it odd.
  29. #102
    Grand Rapids, MI
    #12 maybe? I have an aluminum part that uses #12s. Looking at these I thought they were #10s. Quite a bit smaller than 1/4".
    The diameter of the ID will be about .180".
    https://www.mcmaster.com/91864A052/
    Jim
  30. Thanks MSumners thanked for this post
  31. #103
    Aug 2024
    Damascus OR USA
    I just unwrapped my MAF tube while doing inventory. I tried 8-32 which did not fit so they have to be metric but I didn't have any metric screws small enough to test. It's definitely not a #10.
  32. Thanks MSumners thanked for this post
  33. #104
    Dec 2018
    Hudsonville, MI
    Good call I’ll try the 12. I think that’s not on the thread checker I have. Already had a McMaster order pended so added in
  34. #105
    Dec 2018
    Hudsonville, MI
    This seems like a really reasonable place to talk myself into buying a welder.
  35. #106
    Aug 2024
    Damascus OR USA
    What could go wrong?
