Build Thread Here Partners: Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, Amazon
MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
Used to be but over the past decade that isn’t the case. Hit and Miss at best. My experience has been all misses…over the last 6 or 7 years I’ve probably had a dozen cars come through here with Optimas and EVERY ONE would be dead if they sat anywhere from 5 days to 2 weeks. I now tell customers if you’re bringing me a car with an Optima battery make sure to bring me the charger too.
Had a great morning in the shop today. I got my battery installed and clamped down. It was time to throw the main battery switch, and test all my wiring. I was a bit nervous. Fortunately, everything worked! Fuel pump cycled, horn works, turn signals work, headlights, brake lights, parking lights, hi-beams, hazards...all of it. The only thing I had to do was rotate my turn signal toggle on the dash, as right was left and left was right. Loosened up the bezel nut, rotated it 180 degrees, and tightened it back down. Success!!! I've ordered weatherpack connectors for the lighting, and my trusty Amazon peeps are bringing them to me tomorrow. I'll get those installed tomorrow.
Also primed the oil system, and verified oil at all rockers. Buttoned up the valve covers, checked for leaks (none, thankfully), and called it done!
Battery2.jpgBattery1.jpgDashLights1.jpgDashLights2.jpgHeadLights1.jpgBrakeLights1.jpg
And one other small project. I removed the standard e-brake on the passenger side of the tranny tunnel, since I'm going to use the Wilwood electric park brake. Patched the tranny tunnel, and recarpeted.
Getting all the electrical circuits is in my opinion the single most satisfying milestone after first start. Looking really good
Build Thread #1 https://thefactoryfiveforum.com/show...been-delivered
Build 2 MK4 #11061- Delivered 08/24/24
Build Thread #2 https://thefactoryfiveforum.com/show...006#post562006
Great milestone! No matter how often we do major wiring, untill you "throw the switch" there is all sorts of demons in our heads. Best of all outcomes is no giant blue flash with accompaning billows of smoke calling forth the genie laughing at you for having the moxie to think you could do it! HA! Begone genie! Well done!
