Thanks Thanks:  13
Likes Likes:  5
Page 2 of 2 FirstFirst 12
Results 41 to 50 of 50
Thread: Inner Wheel Damage
    Senior Member Norm B's Avatar
    The passenger side looks OK (could be room for more caster) but, the driver’s side is exactly backwards. With power steering you are trying to get 7 degrees of caster and -0.5 degrees of camber (wheel tilted in at the top)
    Norm
  2. Thanks Doc76 thanked for this post
  3. #42
    Ah crap, I forgot that Doc is on Fox spindles. Thanks for straightening me out.
  4. #43
    Jul 2024
    BC, Canada
    So I discovered something tonight I really do not understand.
    I was checking the range of motion regarding this damage.
    When I turn the wheel left and right, the driver size UCA stays static however when I observe the range of motion on the passenger side (the side with the wheel damage) the UCA lifts up when turning to the right and gets stiff.
    From center (straight) to full left turn, the UCA stays static however when I go from centre to full right, the UCA stays straight.
    Any advice on what to look for would be appreciated
  5. #44
    It’s moving because of caster. We’ve already determined that you have differing caster from side to side. Align both sides alike and they will move the same.
  6. Thanks Doc76 thanked for this post
  7. #45
    Jan 2012
    Central OK
    I think your passenger side UCA is assembled incorrectly. The ball joint plate needs to be removed and flipped front to back.
    Here's a picture of mine for reference:
    Kyle
  8. #46
    Jul 2024
    BC, Canada
    Quote Originally Posted by kgkeys View Post
    Kyle
    Thanks Kyle
    Great eye!!
    I adjusted the UCAs to closer side to side however this had no effect on the range of motion and binding.
    I just went and looked and it is assemble wrong.
    Passenger side is angled up and the drivers is angled down like yours pictured.
    Thanks you so much!!!!!
    This explains why it contacted the rim
    I know what I am doing Saturday
  9. #47
    Jan 2012
    Central OK
    I noticed Craig had mentioned it previously, but once you see it, you see it... Good luck!
  10. Thanks Doc76 thanked for this post
  11. #48
    Jul 2024
    BC, Canada
    Anyone know the part number for the upper ball joint?
    I started correcting the incorrectly assembled UCA today and wasn’t surprised to find the boot is damaged
    Also, my understanding is this ball joint is threaded in with Loctite. What’s the best method to break it free?
  12. #49
    Moog K772 or equivalent. Screw in joint used on literally millions of Chrysler products from the early 1960s on through the late 70s. If red Loctite was used it might require heat.
  13. Thanks Doc76 thanked for this post
  14. #50
    Dublin, OH
    as Jeff mentioned, heat to break the red loctite bond. I also found the correctly sized socket on an impact gun to be necessary. It's a 1-59/64" size socket.
  15. Thanks Doc76 thanked for this post
