Thanks Thanks:  3
Likes Likes:  3
Results 1 to 10 of 10
Thread: Turn signals acting strangely
    Ok so this is stumping me.
    For a while now my turn signals have been flashing, then going solid for 2-30 seconds then flashing again. Everything seems random. It may not show up for a week, then hardly work.
    If they are solid, not flashing, and you pull over the front and rear lights are also solid. The outside lights always mirror what the dash light does. So it’s not a bad light. Happens on both sides. Not related to the lights being on.
    I’ve completely bypassed the column wiring and are using a new switch to try and narrow it down. No change.
    I’ve swapped the flasher relay with the hazard light relay (relay the right word?) and no change.
    So.. what? What random wire loose would
    affect both sides?
    Senior Member Nigel Allen's Avatar
    South Australia
    Replace the flasher can. Potentially both originals are bad.
    Gen1 Coyote / TKO600 / IRS
  3. Thanks RoadRacer thanked for this post
    Simi Valley, CA
    If you have LED lights, make sure that you are using an LED relay. I had to swap the one that came in the wiring kit with this one: https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
    Keith HR #894
  5. Thanks RoadRacer thanked for this post
  6. #4
    Oct 2022
    The LED flashers that FFR supplies have a ground wire. Being that it is intermittent I would make sure you have a good ground.
  7. Thanks RoadRacer thanked for this post
    Likes JimLev liked this post
  8. #5
    Thanks, I have some on order and will try a few offline suggestions and post back here.
  9. #6
    Sep 2022
    Huntington, IN
    Really sounds like a bad ground wire or wires shorting inside the headlight housing or one of the tail light wires shorting against something. With the amount of use your car sees, I can see where a wire could have rubbed itself bare. Didn't you have a fuse issue on this same circuit?
  10. #7
    .Turn Signal, What's That & Where Do You Get Them?
    Oh, I remember that they told us about those things in Drivers-Ed in 1978.
  11. Likes RoadRacer liked this post
  12. #8
    Senior Member weendoggy's Avatar
    Aptos, CA
    b.y.w.b.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
  13. #9
    Quote Originally Posted by Just 1 More View Post
    yeah.. kinda. but there's not much wiring that affects both sides. the ground strap on the flasher, for sure. and the pins on the flasher having a tight fit. so I'll replace it and check those things.
  14. #10
    ok, I got my answer... I replaced the flasher unit and used a new ground - and everything worked flawlessly (so far). I've used for a couple days, so it wouldn't failed by now.
    https://www.amazon.com/dp/B075G5XX5K...fed_asin_title
  15. Likes Just 1 More liked this post
