Thanks Thanks:  69
Likes Likes:  87
Page 10 of 10 FirstFirst ... 8910
Results 361 to 376 of 376
Thread: MB750's MKIV Roadster build thread
  1. #361
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    Got the longer studs today. I tried installing them via a way the internet shows, by drawing them in thru a sleeve of some kind. Many used an old lug nut, but I had some 1/2"x20 nuts lying around from the build so I used one of them. I also anti-seized everything and gave it hell with my impact:
    The two nuts between the washers are drilled out to 1/2".
    Aaaaaaand the nut stripped at this point:
    I love having a 20 Ton press in my garage. Made quick work of the rest:
    Now I need either deep lug nuts, or cut 1/4" off the ends of those lugs. Since that end isn't threaded I'm gonna think about it.
    Matt
    My build thread here
  2. Likes speedfreak1211 liked this post
  3. #362
    Feb 2022
    Tampa, FL
    It's been a while and I've done quite a bit since my last video so here's an update.
    ***Parental Advisory - Explicit Language***
    Matt
  4. #363
    Feb 2022
    Tampa, FL
    Trunk struts done:
    I fished some solid conductor thru a couple holes in the trunk so I could easily pull the wires thru.
    This is where I cut the door panels to reduce the gaps. I'm waiting on the vinyl ester resin, which should come in today:
    LED head lights too. Those incandescent ones from FFR draw almost 11A each when both filaments are on. These are 5.8A each.
    Matt
  5. #364
    Feb 2022
    Tampa, FL
    I was also playing around with the latches and the striker. I made an offset for the striker so I could get the door fully closed.
    But what I noticed is the striker just barely fits into the latch, so I ground down the latch where the striker falls into. Now there's a bit more play and it's smoother.
    I also noticed FFR expects me to drive a few rivet nuts, and compassionately supplies a single 1/4"-20 bolt, nut, and fender washer to install it. Yea......... Looks like an opportunity to make a rivnut installer!
    1/2"-13 left hand thread bolt and coupling nut. My mill drilled it out to 17/64" and Bob's your uncle.
    Matt
  6. #365
    Feb 2022
    Tampa, FL
    Fun fact: I just discovered that if you put fiberglass under tension, then heat it up really hot with a heat gun (but don't melt it), and then let it cool, when you remove the shims it'll pretty much stay where is was previously being held.
    Matt
  7. #366
    Feb 2022
    Tampa, FL
    Now I shouldn't need a few cubic yards of Bondo to smooth out the transitions.
    Matt
  8. #367
    Feb 2022
    Tampa, FL
    Put this affair together:
    And installed the passenger seat and lap belt:
    Then me and the wife went for a spin! Just out around the neighborhood, 7 miles. All systems go, but I do have a little drip of antifreeze somewhere. I'll investigate that later. For now I had a great Saturday with the Cobra.
    Matt
  9. #368
    South Australia
    Nice work Matt. Are you still grinning?
    It's been fun following along.
    Nigel.
    Gen1 Coyote / TKO600 / IRS
  10. Thanks MB750 thanked for this post
  11. #369
    Feb 2022
    Tampa, FL
    Nigel.
    Thanks Nigel. Actually yes, occasionally my mind will go back to Saturday morning with my wife riding shotgun and the car running smoothly. It was a great Saturday.
    Then again last night when I stepped into the garage to pull a beer out of the fridge. When I turned the light on and saw it just sitting there my mind pulled back to Saturday.
    I think we're gonna have some memorable times going forward.
    Matt
  12. Likes Nigel Allen liked this post
  13. #370
    Feb 2022
    Tampa, FL
    I made a charcoal canister out of PVC and some brass fittings. One end takes a 1/4" hose, the other is a cap with a bunch of small holes drilled in it, and the insides is packed full of charcoal bits that I bought from Petsmart that are intended to be used for fish tanks or something:
    Matt
  14. #371
    Feb 2022
    Tampa, FL
    Here's some recent photos for levity's sake:
    Matt
  15. #372
    Feb 2022
    Tampa, FL
    I just realized over the course of this build there's a few different motorcycles in the background.
    This one I'll be keeping around for a while. I inherited it from my dad. It's a 2022 Heritage. My garage only has room for one and this is it.
    Matt
  16. #373
    Dublin, OH
    Quote Originally Posted by MB750 View Post
    Don't know if you did this, but putting some filter elements in either end will prevent the dust/small bits from falling out either end. I used some scotch brite pads cut to size.
  17. Thanks MB750 thanked for this post
  18. #374
    Feb 2022
    Tampa, FL
    I made that thing months ago, and I'm pretty sure I did something, but now I really should to take it apart and see what I did. Otherwise, I've got scotch brite material around here somewhere. That's a good idea.
    I do know I crammed it in there and tamped it a bunch of times to really settle the charcoal. I also made it so tightening down the top cap the last 1/8" would compress the charcoal as well.
    Matt
  19. #375
    Feb 2022
    Tampa, FL
    Steel wool:
    I know it may rust in time, so I'll check it again at the break-in oil change (500 miles).
    Matt
  20. #376
    Feb 2022
    Tampa, FL
    Somebody wants to go for a pup cup:
    Matt
  21. Likes Mike.Bray liked this post
