Thanks Thanks:  3
Thread: Oil Pan for 351W
    Oct 2024
    Oil Pan for 351W
    I have ordered a basic Daytona Coupe kit and am expecting to receive it mid-January.
    I am building a 351W based engine for it and am curious what oil pan works best.
    I would appreciate any guidance on this issue.
    Mike Leach
    Newark, Ohio
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Forte's Parts Connection is a vender on the forum. He supplies engines. I bought my 351 based engine from him. I told him what car I was building and he knew which pan to use. Give him a call. he will gladly let you know and will probably have one to sell you. Mike Forte 508-875-0016
    Scott Pregont
    My Albums
  3. Thanks mikeleach thanked for this post
    Dublin, OH
    I've had luck using Kevko pans. Quality pans and less than some of the other racing pans.
  5. Thanks mikeleach thanked for this post
  6. #4
    Please consider is getting a baffled pan that is a Rear Sump design if possible.
    There is a reason why the Fox Body Mustangs, that sported the 302 engines, had a rear sump.
    The G-Forces our cars can pull during acceleration, turning and even braking can be rather high.
    Oil Starvation is something that you need to avoid if you plan to do any significantly spirited driving.
    Also, please try to set your car up to be as serviceable as possible since you'll be the primary mechanic.
    Good Luck, Watch Your Pinkies & Happy Pan Shopping!
    NOTE:..A rear sump pan can make the engine installation a bit easier since it doesn't hang down as much as a front sump style pan.
  7. Thanks mikeleach thanked for this post
  8. #5
    May 2021
    Fort Worth, Texas
    A second vote for Kevko.
  9. #6
    Junior Member timspx's Avatar
    May 2022
    Moroso pn 20534.
    I’ve used on two builds.
  10. #7
    Jul 2021
    I have a Champ rear sump, trap door baffled pan with a built in windage tray. It fits nicely ony 351w based engine. You're going to need drop motor mounts to use a decent intake. This pan stays above the chassis tubes even with drop mounts.
    Rich
    Coupe R with a 427 SBF
    Tremec TKX close ratio, 3 link rear suspension, 3.27 gear
    Built for 200 treadwear autocross and time attack
    Sponsored by Kenda Tires
