Anybody else do this? Anything to be aware of other than the diameter of the fuel tank inlet?
What a weird place to put a fuel filler, eh? If you do manage to fill the tank more than half, the hose is under liquid level. 10% ethanol? When you go to replace that hose, look for ethanol resistant. I think it's 2".
That was one of the first things I did when I got my kit. I taught myself to weld with acetylene and moved the filler to a doghouse on top of the tank. I'm running 85% ethanol and no problems so far.
Ed
Boyd tank has the filler on the top where it ought to be. I'm guessing that turbo's rotted because it spent a lot of time submerged in fuel that the rubber wasn't up to. A more resistant piece of hose might help.
Ed
