Results 1 to 1 of 1
Thread: For Sale: Factory Five Racing MK4 1965 Cobra Replica
    San Marcos, CA.
    Completed and fully registered/titled as a specially constructed vehicle (SPCNS) in California. Southern California car. Low miles - 4720 as of 01/18/25.
    Many options in addition to being ordered as a complete kit. Dependable Coyote runs great. Body and mechanicals in great condition also. See below for options and pictures. PM for more details or if interested.
    $69K
    FACTORY FIVE MK4 FFR # 8932 Cell 781-883-6818
    Complete Kit Gen 2 Coyote, Tremec TKO600 5 speed
    Dark Epsom Green with Wimbledon White stripes by Jeff Miller Customs
    Epsom Green PPG color code 47674 D. Dyno test report provided
    Options:
    FFR MK4 Complete Kit # 8932. Built with all new parts (no donor parts on total build)
    Ford Coyote Gen 2 stock engine 435 HP. Estimated Dynojet HP 481.
    Coyote engine cover kit
    Coyote mini starter
    Coyote Moroso oil pan and pickup
    Intank fuel pump
    Moroso coolant expansion tank
    K&N air inlet and filter
    4 into 4 full length ceramic coated headers (silver)
    Ceramic coated side pipes (black)
    Breeze upper radiator hinge and lower radiator support.
    Boig Coyote lower coolant tube and hose kit
    GPS gauge set
    17x9 / 17x10.5 Halibrand replica wheels
    Nitto NT555 G2 radials
    Vinyl dash with glovebox. (Removable)
    Center dash support
    Wood steering wheel
    Russ Thompson self canceling turn signal with integrated high/low beam
    Wind wings
    Sun visors
    MKIV FFR logo floor mats
    Assembled side louver set
    Front and rear over-rider bumpers
    Aston Lemans gas cap
    Brake duct wire mesh
    Breeze wire mesh grille
    3:55 IRS rear
    Front swaybar
    IRS rear swaybar
    Black powder coated chassis
    RH and LH powder coated roll bars (black) with grommet set
    Front and rear Wilwood brakes with red calipers
    FF Metals trunk sunken battery box
    Front and rear master cylinder reservoirs
    FF Metals extra thick .060" transmission tunnel top. (Removable)
    Metco driveshaft safety loop
    Powder coated engine bay panels (medium-dark gray)
    All other aluminum panels painted black
    Cool Mat full cockpit heat/sound insulation
    Dual chrome side mirrors
    HalGuard H3R fire extinguisher. (black)
    NOCO Genius 2D onboard battery maintainer
    Headlights, brake lights and signal weather packs
    Herb Fraser custom door panels
    Piggyback Cockpit Cover
    Trunk lid adjustable prop support
    Aluminum seat belt trim bezels
    Carpeted trunk
    Clear vinyl rear fender spats
    Tremec TKO 600 5 speed
    Midshifter pro 5.0
    Hurst 6 3/4" shifter with Tremec white 5 speed pattern shift ball
    HF tool kit
    Car cover
    Notes:
    Wheel spinners removal and install: Drivers side remove (loosen) counterclockwise,
    Install (tighten) clockwise. Passenger side remove (loosen) clockwise. Install (tighten)
    counterclockwise. "O" rings on adapters to prevent spinning when removing.
    4 locations for VIN number/DMV information: 1. Drivers side engine bay top of master cylinder cover.
    2. Inside drivers side door. 3. VIN # etched in under drivers side dashboard on frame.
    4.Under passenger side dashboard on frame.
    Top of transmission tunnel and dashboard are removable.
