Thanks Thanks:  28
Likes Likes:  110
Page 22 of 22 FirstFirst ... 12202122
Results 841 to 867 of 867
Thread: Making progress on my build...
  1. #841
    Senior Member beeman's Avatar
    Indiana
    Mike, I might do that to keep air from catching the bodywork from underneath. Would you use 060 aluminum?
    GTM #304 LPE 525hp LS3
  2. #842
    San Diego
    I'll try and get a picture tonight if I remember.
    I used pretty thin material and then bent an edge on it to make it stronger.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
  3. Thanks beeman thanked for this post
  4. #843
    Indiana
  5. Likes VRaptor SpeedWorks, LLC liked this post
  6. #844
    San Diego
    It looks like .030.
    www.myraceshop.com
    GTM solution kits
  7. Thanks beeman thanked for this post
  8. #845
    Indiana
    It looks like .030.
    OK! So pretty thin like you said, thanks
  9. #846
    Jul 2014
    Now that's some fancy welding. I wish I was half that good .
  10. Likes VRaptor SpeedWorks, LLC liked this post
  11. #847
    Indiana
    Me too, that's why I had this guy do it .
    Measure twice, cut once. Then undo the changes you made
    Going back to the original door length will allow access to "cubbies" behind the seats.
  12. #848
    Indiana
    Side skirts widened by about 50mm. Aluminum sheet support plus a small welded plate at the rear for additional stability at the rear intake.
    20240918_113709_copy_1600x901.jpg20240918_120258_copy_1600x901.jpg20240920_122633_copy_507x901.jpg
    Mounting door outer panel to door frame. Had the fiberglass shop that did my hood and rear spoiler throw together some fiberglass "angle iron". Bonded to door skin, rivets to the door frame.
    20241005_161429_copy_507x901.jpg20241005_164819_copy_1600x901.jpg20241005_171028_copy_1600x901.jpg20241015_173327_copy_1280x721.jpg
  13. Likes VRaptor SpeedWorks, LLC liked this post
  14. #849
    Indiana
    More fiberglass work to match the window seal contour at the rear of the door, aluminum template for layup.
    Fitting the door card, donor upper but will require fabbing lower part to clear the cage/side bars.
    20241018_105454_copy_1280x721.jpg20241018_110036_copy_1280x721.jpg20241021_175644_copy_1280x721.jpg
  15. Likes Power Surge liked this post
  16. #850
    Indiana
    Boxing in the side coolant pipes. Made 2 temples. Started with a flush top which looked really nice. Then I figured I would incorporate the door seal into the piece.
    20241021_181615_copy_1280x721.jpg20241021_182826_copy_1280x721.jpg20241021_182922_copy_406x721.jpg20241021_182927_copy_1280x721.jpg
    Final design, should be a nice door seal with the weatherstrip.
    20241021_185513_copy_1280x721.jpg20241021_185953_copy_1280x721.jpg20241021_190047_copy_1280x721.jpg
  17. #851
    Jan 2024
    I love your attention to detail, as well as the patience that you have building this car. I haven't even had mine a year, and I struggle at times with how long I foresee it taking to complete my car.
    Sal Mennella
    Unfinished GTM #30 FFR - in progress!
    Roadster 5132 - sold
  18. Thanks beeman thanked for this post
  19. #852
    Wow.....what an incredible amount of work you've put into that! Looks like it's coming along pretty nicely!
    Shane Vacek
    www.vraptorspeedworks.com
  20. Thanks beeman thanked for this post
  21. #853
    Indiana
    Quote Originally Posted by Power Surge View Post
    Luckily I have other projects that I can bounce around on when I need a break. My GTM is by far 10x the work compared to the other car projects I have... But I think it will be my favorite when it's done.
  22. Likes VRaptor SpeedWorks, LLC liked this post
  23. #854
    Indiana
    Passenger side was the prototype, made great progress on the driver's side last night and today. Symmetry is the ultimate challenge here, especially starting with the asymmetric GTM body.20241213_123221.jpg20241213_123242.jpg20241214_143411.jpg
  24. Likes VRaptor SpeedWorks, LLC liked this post
  25. #855
    Indiana
    Cut... Paste... Cut... Paste
    Why is the site posting my photos rotated all of a sudden?
  26. Likes VRaptor SpeedWorks, LLC liked this post
  27. #856
    Jan 2024
    This is such a cool build, Dave. I love seeing the progress.
    Sal Mennella
  28. Thanks beeman thanked for this post
  29. #857
    Indiana
    Driver's door bodywork nearly done.
    Was considering options for license plate mounting with the center exit exhaust, including below one of the taillights. Will mount it above the diffuser. Ordered diffuser strut mounts to finalize diffuser location. As it sits, diffuser angle is 18 degrees which is on the high end but I think it will be functional with the spoiler assisting it.
  30. Likes Jkviper liked this post
  31. #858
    Indiana
    Finished the passenger side rear trunk. Tons of storage space back there. Need to order more 040 aluminum to do the driver's side.
    20241226_142946.jpg20241226_143335.jpg20241226_145040.jpg20241226_145050.jpg20241226_145103.jpg
  32. Likes Shoeless liked this post
  33. #859
    Jan 2024
    Really cool engineering as always. Do you have a rendering of what you expect the car to look like when done?
    Sal Mennella
  34. #860
    Wow....you're going to have a ton of storage space there!
    Shane Vacek
  35. #861
    San Diego
    Hey beeman. Looking at the rear picture you have there...don't mean to be negative or anything...but in my experience with these cars, you are going to need a lot more ability to evacuate hot air out the back of the car than what you have there. I understand that this is just work in progress shots and maybe you have a plan. Just trying to give you a heads up before you are too far down a particular path.
    www.myraceshop.com
    GTM solution kits
  36. Thanks beeman thanked for this post
  37. #862
    Indiana
    Mike- I'm hoping that my setup won't have significant heat issues. I'm going to use Shane's aluminum vented aluminum hatch insert instead of the supplied glass. I will have venting above the resonators on my rear trunk panel as well to help the exhaust heat to escape. I'm also dropping the diffuser which will open the rear quite a bit. I'm a NA 525hp so I'm not pushing the limits with forced induction, etc. What do you think?
    I did one back in 2017 (holy cow), but quite a few changes since.
  38. #863
    Indiana
    Working on finishing the bodywork, found my way around to the engine air intake. Started analog with paper and Styrofoam, then realized that I will be making a mirror image on the passenger side (fresh air into the engine bay vs oil cooler) because it's going to look lopsided if I only put a snorkel on one side. So off to CAD, a bit rusty, can't remember the last time I used it. I'm using the existing Lamborghini Evo style intake that I drew up previously, now I need to duct that intake to the GTM body at the rear 1/4 window which feeds my airbox. The body has compound curves in this area, so I'm not going to be able to print something that will be perfectly formed to the body ( I don't have a 3D scanner). So I drew up a duct, will print it, and will blend it to the body and make a fiberglass part. Printing will help keep the driver and passenger sides symmetric.
    Existing snorkel
    Abandoned the paper and foam pretty quickly...
    New transition part between snorkel and body, the 2 parts will mate together to make 1 part
    Again, loosely based on the Lamborghini Huracán GT3 EVO2
  39. Likes VRaptor SpeedWorks, LLC liked this post
  40. #864
    Feb 2019
    Houston, TX
    [QUOTE=beeman;571383now I need to duct that intake to the GTM body at the rear 1/4 window which feeds my airbox. The body has compound curves in this area, so I'm not going to be able to print something that will be perfectly formed to the body ( I don't have a 3D scanner). So I drew up a duct, will print it, and will blend it to the body and make a fiberglass part. Printing will help keep the driver and passenger sides symmetric.
    [/QUOTE]
    About a year ago I started on the same task for my 818, scoops for the 1/4 windows to feed air box. I got 2 revs printed and test fit before I had to shelve the 818 for a few years. Hopefully you finish before I resume and I can improve my design based on your work
  41. Likes beeman liked this post
  42. #865
    San Diego
    Sorry the quote function is not working, but back to post 862...I ran a 525 LS3 for quite some time and it needed all the air evac I could get. I too have gone over to Shane's aluminum rear window and it works very well. Lots of air can move through that insert. HOWEVER, we did a string test to see how air is actually moving out of that louvered rear insert and you might be surprised that air is actually moving INTO the engine compartment and very little is moving out with that insert. Of course we have the entire rear of the car open for air flow so it might be different than what you have there. You can always cut it open later. That's what we did as we developed the race car. It started with everything intact and then went to more air flow as needed. Closing up the floor behind the driver and under the engine area really boosted the requirements for more air evac from the engine area. I also have wrapped the exhaust in four layers of Lava Wrap. We closed in the 1/4 panel vents after the fire where the driver got his suite singed by the flames that came forward out those vents. Probably not as big an issue if you are using those vents with a sealed connection to the engine intake. My suggestion is to leave the rear how you have it and just be prepared to open it up when/if it is needed. Maybe keep this in mind when building body supports and such.
    www.myraceshop.com
    GTM solution kits
  43. #866
    Crash.....yeah, that makes sense if you have a really effective path somewhere for air to be drawn out of the engine bay....that it would be drawing air into that louvered window replacement panel. As you said, whether that panel draws air/heat out, or allowed fresh air in is going to depend on what other methods you're using to both get fresh air in and draw air out. If you install that panel on a car that has our diffuser louvers installed, I would fully expect for those louvers to have more "pull" than the hatch area.....so air would flow toward the diffuser. On cars without the diffuser louvers and a good path for air to be forced into the engine bay, I would expect that the heat/air would flow out of the hatch panel.
    Shane Vacek
  44. Likes Shoeless, beeman liked this post
  45. #867
    Indiana
    Some things aren't apparent until assembled and on the car. The first prototype had the contours of the snorkel continued towards the rear of the car, rather than perpendicular to the face of the intake. This has been corrected. (this isn't evident in the photos as spacers were added to correct this).
    The first prototype also had the face of the intake parallel to the surface of the car bodywork, rather than parallel to the duct body. This also has been corrected. (this also isn't evident in the photos as spacers were added to correct this). I also brought in the outer margins of the base about 5mm to better fit the 1/4 window recess.
    20250104_140709_copy_900x1600.jpg20250104_140637_copy_1600x900.jpg20250104_144925_copy_900x1600.jpg20250104_140935_copy_1600x900.jpg
