Thread: Expert advice needed: Powder coating material cost/volume
    Sep 2024
    Roadster build….If you plan to powder coat both sides of all your aluminum panels…..how much “powder” and prep material is needed? I have a friend/of a friend who is a retired professional Powder Coater (still has all the equipment) and is willing to do all my parts as long as I cover the cost of material…I do not know how to respond to that???? (Except for a big thank you)
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    Powder is pretty cheap. Usually about $10-15 per pound. I like Prismatic Powders, personally.
    While I haven't done my coupe panels yet, I will be coating them myself. I'm anticipating I'll need around 8-12 lbs. More if wanting a 2nd coat, obviously .
    Should be similar for the Roadster.
    Prep involves cleaning/degreasing the panels, then either etching by blasting or with chemicals. Then a final cleaning. So it's depend on what your friend's method is.
    Gen 3 Coupe #576 - "Project Deimos"
    Ordered: 2/14/2024
    Received: 5/24/2024
    Build Thread: https://thefactoryfiveforum.com/show...upe-has-landed!
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    The cost of the powder is much cheaper than having it professionally done. I pay about $12 a lb for powder. I paid about $600 to have many of my panels coated.
    Mk4 complete kit arrived 10 May 23
    Current BOM
    Senior Member gbranham's Avatar
    Jul 2021
    Tonganoxie, KS
    Quote Originally Posted by JimStone View Post
    8-12 pounds! That's nutty! I used Prismatic on mine, and my powdercoater covered every one of my panels front and back. He had plenty of that single pound left over. It was an $18 bag.
    Greg
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
    Nov 2022
    Niles, MI
    Quote Originally Posted by gbranham View Post
    Greg
    Haha, I might be overestimating! I've only powder coated small parts so far, so I was extrapolating
    Ordered: 2/14/2024
    Received: 5/24/2024
    mburger's Avatar
    Punta Gorda FL
    I paid a local powder coater $1,000 to coat only the panels that would be seen in and around the engine bay.
    So Henry and I bought a 2' x 2' x 5' powder coating oven. There are SO many smaller parts that we would pay to have coated that this should pay for itself within the first year.
    Mark
    Gone but not forgotten. Mk1, Frame #1929 Complete restoration/upgrade.
    Falmouth, MA
    I picked up a used pizza oven that is 5' x 3' with about 16" tall opening. It's 240 volt but works fine with my Eastwood powder coat gun and materials. The oven came on a stand but the whole thing must weigh about 500 pounds as it is lined with some type of oven brick. I got it for free just to remove it from the site.
  8. Likes mburger liked this post
