First build complete!
Thank you all for contributing to the forum and help steer my process.
After 7 months I have my first MK4 done!!! Well mostly. I still need to skin the door cards and get it titled next week and waiting on some trim rings for the roll bars before final installation. I havent done any cutting/buffing yet so thats on the to do list but as far as having a fully functional roadster, I am happy to call this one complete!
Chassis 11037 Complete kit with IRS
ordered 3/27/24
completed 05/11/2024
delivered 5/19/24
First start 9/7/24
Painted 12/19/24
Completed 1/7/25
Gen 1 Coyote with TKX
Power steering
Northracecar AC
Breeze front battery tray and fan shroud
IE 427 turn signal
Trunk gas struts
275 17s on front and 315 17s on rear
I went with black chrome for the overriders, gas cap, louvers and headlight outer ring. Left the rest chrome for contrast.
Cant wait to drive!
Mk4 Complete Kit 11037. Ordered 03/26/24 Delivered 05/29/24 Complete 1/7/25. Powdercoat, IRS, Gen 1 Coyote Donor, North Racecar AC
Post Thanks / Like - 0 Thanks, 4 Likes
Nicely done! Love the color and what I assume is an ahooga horn up front!
Sarcasticshrub
It most certainly is an ahooga horn!
Looks great, although looks like the hood needs a little adjustment at the front!
cob427sc
I put some D weather seal but it's thicker than it should be so waiting on some thinner seal. Sits flush with just the rubber bumpers but seeing if I can get this to work.
bartock
Try some 93085K67 and 93085K14 from McMaster Carr.
How did you wire your digital rear view mirror? I don't see any wires in that photo. Car looks great!
Blitzboy54
I havent found a permanent solution but for now the wire runs underneath the car through the trans tunnel and back through a grommet in the firewall. It is accessible and I can pull it out and plug it in when needed. I am trying to find a better looking way to run the cable up the windshield post and along the top. Right now I just have it attached to the windshield with a universal suction mount. I didnt want to do anything permanent until I knew for sure where it would stay. I was thinking about getting a top for it and wanted a corvette style rear view that runs off a camera feed.
Congrats!
16+ FFR kits and counting!
Well done! And quickly, too!
BUILD in progress:
MKIV delivered Sept 2023 BPE 347 Tremec Five Speed
MaxVmo
Thanks! Still need to tweak a few things but will go to the DMV Monday and hopefully get everything 100% squared away. I work for an airline so I end up with blocks of days off, and mostly home half the month. If I was doing a Mon to Fri job with only the weekends to work on it I would be nowhere near done Im sure.
Art Shand, Big Canoe GA
BPE 347 FI, Hydraulic Tremec TKX, Wilwood front & rear, GAS-N Headers/Touring Pipes, many functional upgrades.
Mike.Bray
Thanks the smaller bulb seal was enough for both doors and hood. I used the thicker part around the back and transitioned to the 5/16 down the sides and front. Lifting the back hinge just a hair let it sit down right.
Thanks!
