Thanks Thanks:  2
Likes Likes:  3
Results 1 to 11 of 11
Thread: Need some seat adjustment suggestions
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    After putting a few miles in the OEM seats I'm starting to want some adjustments. Specifically, the backward lean angle, and lumbar support.
    For the lean angle, I was just gonna shim up the front. Regarding the lumbar, does anyone have any suggestions?
    Thanks.
    Matt
    My build thread here
    Senior Member PNWTim's Avatar
    Nov 2020
    Damascus OR USA
    You can use something like this:
    https://www.summitracing.com/parts/c...QaAhO2EALw_wcB
    Or something as simple as a gel pack. Depends on how discreet you want it to be.
    Build 1 - 1969 Camaro Build Thread Here: https://www.camaros.net/threads/tims...y-getter.45926
    Build 2 - 1965 Daytona Coupe # 620 Build Thread Here: https://thefactoryfiveforum.com/show...-Type-65-Build
  3. Likes Doc76 liked this post
    Feb 2022
    Tampa, FL
    Quote Originally Posted by PNWTim View Post
    I like that, and it's adjustable.
    I'll probably install it under the vinyl. I'm doing seat heaters anyway so it'll be apart anyway.
    Matt
    O'Fallon, MO
    Seat heaters in Florida---AC in Alaska---??
    Dublin, OH
    I was just in FL last week, panhandle area.
    30-40s at night, daytime highs of 50-60s.
    I'd definitely use seat heaters there.
    In OH, definitely extends my driving season well into mid Nov.
  7. Thanks MB750 thanked for this post
  8. #6
    Copperhill, TN
    Breeze Seat Mounts will give you that slight recline and a small amount of adjustibility
    https://breezeautomotive.com/shop/in...classic-seats/
  9. Likes MB750 liked this post
  10. #7
    Ted G's Avatar
    Aug 2021
    El Dorado Hills, CA
    Quote Originally Posted by John4337 View Post
    I second the Breeze adjustable mounts. They also may help a bit with lumbar as you'll be tilted back a bit. I also added seat adjusters on top of the Breeze mounts.... being on the shorter side, it was nice to get that extra inch or so.
    #10333 Complete Kit, Carbed 427w, TKX, IRS and many other upgrades
    • Order Date: September 11, 2021 - 20th Anniversary of 9/11
    • Delivery Day: April 1, 2022 - April Fool's Day
    • First Start and Go-Kart: January 20th, 2023
    • Graduation Date: July 4th, 2023 - Independence Day!!
    • Legal Registration Date: October 4, 2023 - My Birthday!!
    Visit my MKIV Build Thread (#10333)
  11. #8
    Feb 2022
    Tampa, FL
    Exactly! As a very long time motorcyclist, convection really sucks the heat out of anything. Standing in the sun at 70F is nowhere close to the same as ripping down the highway at 75 mph at the same temp.
    Thanks for the tips fellas.
    Matt
  12. #9
    Sep 2011
    Minneapolis, MN
    I’m with ya … touchy lower back, but when I got the tilt dialed in it was so nice I never got around to lumbar support. I drove around with a 2x4 under the front of the seat for extended go karting until I was convinced the tilt was right. Then I cut a chunk of square steel channel of the right height and bolted through it when mounting the seat.
  13. Likes MB750 liked this post
  14. #10
    Jun 2015
    Fairfax Station VA
    Aircraft Spruce sells seat cushion foam https://www.aircraftspruce.com/catal...?clickkey=4682.
    MK IV Roadster #8631
  15. #11
    Senior Member mrglaeser's Avatar
    Jan 2020
    Twin Cities, MN
    I have seen a lot of people using aluminum spacers to rise the seat. That what I purchased if a few sizes. Here are some examples on Amazon (I don't remember off hand which were for the seats and which were used for accessory drive brackets) there are other places to purchase:
    https://www.amazon.com/dp/B0BN6RQLL3...c_as_ri_0&th=1
    https://www.amazon.com/dp/B09TY5Z6NV..._TE_sc_as_ri_0
    As for lumbar I use something similar to these.
    https://www.amazon.com/Back-Cushion-...rEALw_wcB&th=1
    Mark IV, 302 Based 347, TKx, Four link w/3.55, coil overs, PS, 4wheel Willwood. Dark Blue w Black/Red stripes, Saddle Interior, Blacked out chrome.
    Kit Ordered 4/18/2022
    Kit Delivered 2/20/2023
    Engine Install 9/15/2024
  16. Thanks MB750 thanked for this post
