NuHale 65 Coupe Build Thread - General Update
Wasn't planning on it this early in 24' but with the announced sale and potential for price increase I decided now better time than ever and jumped in first thing today. Deposit down with an end of May pickup planned. Looking forward to the build as even though I love my MKIV I really miss the building process.
Went with a 65 Base Coupe kit. Build plan has been underway and already have a good amount of parts but a quick list of build plan:
Base Kit
IRS
Front FFR LCA
TKX (unsure of gear)
Coyote (TBD on pullout or crate) I'm leaning towards a GEN 2 if I can find one reasonable.
Forced induction (pref centrifugal but fit will be issue)
Mustang cut out rear end (10k) with 3.55 differential (may swap to 3.31 gearing) brakes, spindles etc.
Forgestar F14 19"
Rear 15+ IRS single piston brake (13" rotor) and 2004 Cobra SVT Fronts (13" Rotor)
First question to the forum is on IRON vs. Alum Diff. I see lots of posts on this but with the power I'm planning guessing an Iron housing is ideal.
more to come but pumped to get going!
Build 1: MKIV #7275 Gen 2 Coyote TK600, IRS 3.55 2020 Graduated
Build 2: Gen3 65 Coupe: Arrived June 2024. Gen 2 Coyote, T56, IRS 3.55
Congratulations! I took the plunge today too! Coupe complete kit. I also wasn't quite ready, but FOMO kicked in with the sale and upcoming price hike
I'm Jealous!
Congratulations!
I have new in box front two piece spindles if you’re interested.
Originally Posted by
cv2065
Congrats!!
thx Chad- hope your build going well
Kbl7td
thx for the offer but the base coupe kit now comes with spindles... need Front LCA if anyone has.
On a roll
so will this be "cubcoupe" on the plate? oh wait, that's too many letters, isn't it.
Congratulations! Love our Coupe. Only said that about hundred times now... For the IRS center section, when Factory Five first released that new design IRS, they said iron case only. Since then, they've changed that to say either iron or aluminum. Unless you're planning super sticky tires, like drag slicks or whatever, either is fine. Even then the center section probably wouldn't be the weakest link. Probably the CV axles. That's one of the first things the Mustang performance guys upgrade.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
As I went with the base kit still sourcing some parts. Picked up a set of rear IRS spindles, RF wiring harness, Brock racing mirrors amongst other small parts. Also planned on doing a full mustang cut out to supply the brakes, spindles and differential but with the deal I got on new spindles I'm probably going new differential (3.55). Still plan on used rear brakes and will rebuild and powdercoat. Lucked out on a Gen 2 coyote pullout with 12k miles. Still planning on a TKX but can be talked out of for a T56. I scored a new QT6080 bellhousing for half of what they are going for these days and with the T56 a grand more wondering if I will really see a value here or put the money somewhere else.
Picking up engine this week and will need a little work. Missing valve covers and as I'm planning a boost build (leaning towards VMP Loki/Odin or gen3r) plan to put in a boundary OPG/cam sprocket and considering pulling the heads to inspect pistons, and swap to ARP head stems. I've heard both sides of this and that they may not be needed. Will also swap pan and pickup and add B302 alt and a mustang compressor as I will add AC. No hydro pump on this one as plan to go with E-power steering. Opinions welcome!
nuhale
I assume you know that 6060 bell is good for your TKX, but not the T56. That requires an 8080. That may sway your decision, I don't know. I love the T56 in my Coupe. Really like the two overdrive ratios. I like the reverse lockout, although maybe not appreciated by everyone since it adds a little work on the installation. The T56 shifts like butter. Something the TKO wouldn't do at the time I built mine. Unless modded, e.g. Liberty Gears which I did a couple times. The TKX by all accounts solves the shift issue. So that makes the decision a little harder. The T56 + Coyote fits into the Gen 3 Coupe without any drama. Bottom line for me, I would do a T56 again.
I had electric PS my truck. First time I've tried it after multiple builds with traditional hydraulic PS. I personally didn't care for the feel of it. I've heard others say the same thing. But others like it. Obviously, very subjective. My experience on my last two builds was the KRC pump with good quality racks. Outstanding setup.
Build Thread and
Video.
Build Thread and
Video
edwardb
Thanks for the feedback Paul. I'm sure I'll seek you out in June at LCS to talk some more shop. I do know the details on the bellhousing. Just saw this one a few weeks ago and couldn't pass on it so even if I did make a change in my build plan I would offer it up to another builder. Still in disbelief that the QT bells have almost doubled in cost in just a few short years... such is life these days. Thanks for the e-power steering feedback. I have a Forte saginaw pump setup on my MKIV. I've been really happy with the feel. It powers my hydroboost as well. I have the manual rack from the roadster build so was considering just using that with the epower and save a few bucks. Certainly do some more research on the options. Not a huge thing to change but need to be aware of front engine belt space with considerations of a blower.
On a roll
Showing my ignorance here, but I have to ask this question: if you are concerned about the ability of the cam sprockets to handle the power you expect, what about the crank and connecting rods? I would think that the parts are matched to handle the same amount of power from the factory. Are the sprockets the weakest link?
Al_C
It can start a debate but a well-known weakness of the coyote is the oil pump gear. It's a cast part and has shown failure at high RPM situations. Many just swap it out with a billet gear from boundry. Common swap but have heard both sides of it. Not a huge change when engine in on stand and a cheap insurance policy. All other stock components are pretty durable and can handle boost. Only other area may be the ARP head studs which is another easy one if I'm getting into the engine.
On a roll
nuhale
Thanks, Bryan! I appreciate the explanation. Thanks for indulging me!
I'm feeling you on the sale, wasn't exactly ready to start my build, but I'm about to put down a deposit too before I have to pay $5k more a year from now.... Damn marketing lol
Looks like a lot of fun!!
Not a waxer
Looking good buddy!
Received the adapter and had a free hour tonight so just did the leak down test on the Gen 2 coyote. Results pretty darn good. As written the engine is a pull out donor that was reported to have around 12k miles. This gives me big peace of mind to move forward. Just a small plug for the harbor freight tester. I've used the older one and that one is a POS to say the least. This one is either a dead on knock off of the OTC or made by same supplier. It is identical in every way. Works great!
On a roll
Good news! Oh wait, didn't you say something about OCD? Never mind. On another note, how many miles do you have on your Mark IV? I bet these two engines are close, mileage-wise. I'm glad this is working out for you and I think the coupe engine is going to be incredible! I think this whole adventure is really worthwhile!
Al_C
Just under 11k I think. I’m gonna try and bring her home from storage this weekend if the weather holds. Aren’t you in Texas Al?
On a roll
nuhale
Nope. Too many conflicts, and too long a drive. I will be at LCS, though!
About a week out from driving out to Boston to pick up the coupe from FFR and Trans/random parts from Mike Forte. Some of the purchasing has slowed due to work travel and other projects (mostly getting garage ready). Have my MK4 home from winter hibernation and got through some of the annual maintenance there. Finished getting the Gen2 coyote reassembled and painted. Really happy with result of the Ford corp blue Eastwood ceramic engine paint I used with black engine dress and powder coated oil pan. Much of this not really seen but really like the little details that I didn't do on the roadster. I plan to use a Holley low ram intake, but TBD based on some other decisions that need to be made or what will fit.
Build Plan as of May
BASE KIT
- Gen 2 Coyote 11k mi (rebuilt/upgraded) ARP head studs, Boundry OPG, upgraded timing chains/tensioners, Moroso oil pan
- Tremec T56 6spd
- Quicktime 8080
- IRS
- 13" Fox Mustang Cobra Front "Big Brakes" Hawk HPS Pads
- S550 Rear Brakes Hawk HPS Pads
- Super 8.8 3.55 rear end
- McLeod RST twin disk clutch
- Speedhut FFR gauges
- F/R Sway Bars
- Added front LCA
- Koni Coilovers
- FFR AC/Heat
- Side windows
- RF wiring harness
- Specialty Power Window WWK-2 wiper kit
- Brock racing side mirrors
- Rear S550 (new) IRS spindles
- Power steering (Leaning towards TSP 84053BK-KT - Kit that uses saginaw pump)
Other than the engine, no donor parts. Lots of debate around complete vs base kit. I opted to go base and buy what I need. Will document the process as with the roadster I changed out a ton of components.
TBD
- Supercharged? Not sure what I'll do or what I can fit
- Holley Low Ram intake
- Interior - leaning towards Kirkey 65' road race seats with custom leather
- Forgestar 19" wheels F14
- Denny's driveshaft
- Tires
Pretty awesome. I'm picking my Coupe kit up next week too - Friday
JimStone
Same. Friday before noon is plan. Depends on how long I spend chatting with Mike Forte.
My kit gets picked up tomorrow and delivery is supposed to be Friday-Sunday. I'm sure I'll find out tomorrow.
Retired Army. 2020 Roadster Complete Kit, Gen 2 Coyote w/Gen 3 Intake, and 3.55 IRS. 2024 Coupe Gen 3 Coyote Complete kit, 3.73 IRS, T56 Mag.
nuhale
Cool! I'll be there at 10am. See you there, haha
I'm hoping to meet Dave Smith. Hopefully he's available
Congrats on the kit!
I was the next pickup after you. Sorry you didn't get to do the tour. Dan Golub showed us around, then Dave. We had a great time. Was worth the drive, for sure.
On a roll
I look forward to an update when I see you in OH! I was wondering if maybe the coupe might be ready... This is a really exciting project. I'm envious!
Not a waxer
nuhale
...Did have a slight run in with the Grand County Sheriff where I received my first ticket in 25 years. Doing burnouts in Grand Lake area is not welcomed apparently...
Darn out of state hooligan with a loud car
Some progress to report. Completed pre fitting and drilling all the aluminum panels. Decided to use a few techniques on this build to lessen the powder coat cost. Using the gold foil/fiberglass adhesive sheet on panels facing the engine for a nice aesthetic and hoping some function (thanks Erik). Most of the panels in the engine bay other than the gold footboxes off to powder which going with a matte wrinkle finish.
I will be using sound deadening material in the cab I picked up on amazon. Will be using a combo of 80/120mil rubber/foil sheet with some additional sound deadening mat. More to come on this front. For any of the panels that are slightly seen in wheel wells or under car (ie underside of tunnel) I will be using a vinyl adhesive material. I did some testing on it and it holds up pretty well. Goes on like vinyl signage or car wrapping with some soapy water that gets squeegeed out. 50' roll was $30 so easy decision. I'll attach some photos when I get the panels wrapped.
Just some other odds and ends for engine etc. Keep finding those deals. Picked up a new BOSS302 alternator kit for half. Looked kinda strange on my blacked out gen 2 coyote so break out the POR15 and a little time to paint.
Next up is finishing the fuel and brake lines. Will be using Nicopp brake and AN flexible PTFE braided line. Moving along nicely. Hoping to get to first start end of October but that work thing keeps getting in the way.
Looking good!
I picked up my coupe kit the same day, but you're way ahead in progress.
Love the wheels. I'm actually planning same wheels/specs, but in gloss black.
Looking good! Any wheel clearance issues with that setup?
On a roll
Thanks for posting, Bryan! I was wondering how this build was going... Wheels look good. Can't wait to hear about a first start. Chances of it being ready for London???
Looking great!! I'm about the same on the posting cadence.
