Thanks Thanks:  3
Likes Likes:  2
Thread: Specialty Power Windows Wiper Motor Mount Question
    Senior Member TTimmy's Avatar
    Sep 2021
    Emmaus, PA
    Hi Folks,
    I am looking for input on the mounting location of the Specialty Power Windows WWK-2 wiper motor on my coupe. The most straightforward option would be to mount it directly to the firewall above the PS footbox as in the photo below. My current thought is to use the supplied hardware and run the bolts from inside the firewall which would enable removal or maintenance of the system from the engine compartment.
    I have seen it mounted on the firewall with standoffs or brackets and also on the top of the footbox. Wondering if this is a preference or a requirement.
    After putting 3000 miles on my coupe this summer I decided I need to upgrade my wiper setup. I have the body off right now as I am starting bodywork so this is the time to get this sorted out.
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thats the location I put mine. I did offset mine just to give the cable a straighter run. Others have not. Personal preference I guess.
    Scott Pregont
    My Albums
  3. Thanks TTimmy thanked for this post
    Mine is on the firewall in a similar location that you pictured. Just rotated slightly to point at the first wheel box. I have it on rubber standoffs. Works fine. Had only seen a few sweeps in my first several seasons. But was in a real rainstorm this past season. Did the job.
    Sep 2021
    Emmaus, PA
    Thanks for the input.
    Do you guys foresee any performance issues with mounting it directly to the firewall versus using some type of standoff? I expect (hope) they will only get light use.
    Quote Originally Posted by TTimmy View Post
    I mounted mine with rubber mounts to reduce the noise a hard mount could make in the cockpit. I made some extensions and bolted on per the picture. I didn't want to use the four corner bolts directly since they also hold the case halves together. It's complicated in there plus messy with the packed grease. I didn't want it coming apart while mounting, removing, etc. I don't think there's anything critical about any of this. Mostly personal preference.
  7. Thanks TTimmy thanked for this post
    Likes TTimmy liked this post
  8. #6
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Mine is on a roadster, but essentially the same thing. I mounted mine directly to the firewall, but I reversed the screw direction so the the screws come through the firewall. There's one set of nuts (inside the case, not visible) that hold the back half of the case to the firewall which are secured with loctite. The second set of nuts on the outside secure the outside of the case. This way I can disassemble it if needed by remove the outside set of nuts, which will allow me to remove the outer casing while the back half of the assembly stays attached to the firewall. I haven't used it that much, but the few times I've used it, it worked perfectly and quietly. I did install the thicker FFMetal firewall, though.
  9. Thanks TTimmy thanked for this post
  10. #7
    Sep 2021
    Emmaus, PA
    Quote Originally Posted by JohnK View Post
    Thanks all for the input!
    I ended mounting it as JohnK has done. It provides access and serviceability to the motor bits. My only slight concern at this point is are the bends necessary to hit the first wiper box. They will be pretty mild compared to some other I have seen and certainly less than the 3” bend limit outlined in the instructions. I can always tweak it and add standoffs later if needed for better alignment. But I don’t think change plane on which it operates will have any effect on the rotating shaft within the tubes. But I am no mechanical engineer either.
    Next project will be to diagnose the parking issue with the old motor and get it installed in my Mk3 basket case project. I guess the good news is that I have two partially broken FFR motors that I can hopefully cobble together into one good one.
