Thanks Thanks:  4
Likes Likes:  4
View Poll Results: Heat Shields or No Heat Shields
Voters
33. You may not vote on this poll
  • Heat Shields
    20 60.61%
  • No Heat Shields
    13 39.39%
Results 1 to 29 of 29
Thread: Heat Shields or No Heat Shields...that is the question
    Senior Member Rebostar's Avatar
    Jan 2024
    Looking for more opinions. I bought a set of heat shields but was thinking they might look a bit cheezy. I like the look without them better.....however I dont want the "chief" to get snake bit.
    Hence a new poll.
    Heat Shields:
    No Heat Shields:
    RJD's Avatar
    Northern Virginia
    Without heat shields, you only have to let your guard down once. A snake bite is bound to happen.
    If you think yours look cheezy, how about trying shields with a different design?
  3. Likes Nigel Allen liked this post
    Aug 2022
    Portland, Oregon
    I have a set from Drummer Mike you can check out. The are solid and look pretty nice.
    Jan 2024
    Quote Originally Posted by RJD View Post
    Those look cool. Where'd you get em? Cost?
    RJD's Avatar
    Northern Virginia
    Quote Originally Posted by Rebostar View Post
    I'll PM you - he's not a vendor here.
    Jan 2024
    Got it....Thanks much
    Use shields especially on the passenger side. It really isn't a matter of will someone get burned, just a matter of when. It HURTS, and it is ugly, for a lot longer than you would expect.
    Senior Member nuhale's Avatar
    Jun 2019
    Gurnee, IL
    Those look like Backdraft heat shields. I have the same set. I think they fit a "traditional" aesthetic better than some of the other options out there. Just my opinion. I think not only do they provide a benefit, but they also look cool too.
    Build 1: MKIV #7275 Gen 2 Coyote TK600, IRS 3.55 2020 Graduated
    Build 2: Gen3 65 Coupe: Arrived June 2024. Gen 2 Coyote, T56, IRS 3.55
  10. #9
    Sep 2011
    Minneapolis, MN
    Photo of Drummer Mike's for reference. Nice pieces and blend right in.
    Ditto to everything that's been said - you need some version. Just as you need to remember that none of them cover the bend in front of the collector. For when you stopped at the gas station and are cleaning off your windshield. For instance.
    Untitled by John Ibele, on Flickr
  11. #10
    Senior Member MPTech's Avatar
    St. Louis, MO
    I've had the Drummer Mike shields for 10+ years and prefer the clean / no cut-outs / no bolt heads appearance.
    Before I got them, I warned my nephew and my dad multiple times before entering, both earned minor burns for not heeding my repeated warnings.
    I never burned my legs, but I did get reminded a couple times for getting too close.
    I have seen some painful & permenant tatoos posted here.
    Don't risk it!
    Also, be mindful of children getting too close to the bend / body exit when parking at car shows & Cars/Coffee events. They like to see the engine when you first arrive and pipes are still HOT!
  12. #11
    Fairfax Station VA
    In addition to heat shields, I use a piece of welding mat (https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1) to cover the exhaust tip. If you don't like the heat shield, you could use only the mat.
    My son would burn his leg EVERY TIME without the shields, and many times without the mat.
    MK IV Roadster #8631
  13. #12
    Aug 2023
    Rochester NY
    I heard about the snake bite so many times at London last year I went under car exhaust. Exhaust has to exit in front of rear wheels however due to the IRS. Depends if you must have that side pipe look.
    Waterman
    MK4 Roadster started February 2024
    302 carb, TKX, IRS, under car exhaust
  14. #13
    Car is about 9 years old with Drummer Mikes shields from day one. Had a 67 StingRay with Hooker outside pipes. Learned about the StingRay Sting the hard way.
    Quality product that still look new without any special maintenance. For heat did a suspenders & belt approach, the shields are lined with Thermo-Tec
    Kevin
    MKIV #8234
  15. #14
    Edmond, OK
    I took the poll, and voted "no" to shields - but I have the double-wall stainless Flowmaster mufflers that the shields would cover. Get in front of that on the 4 tubes, or behind that with the tips - shields don't cover those areas anyway.
  16. #15
    Senior Member TBull's Avatar
    Dec 2011
    St. Louis
    I had drummer Mike's shields on my last car and I'm adding them to the new car this spring.
    FFR #4402 MKII Supercharged 308 445 RWHP Sterling Grey W/ Black Sapphire Stripes, Purchase 8/22/2008 Sold 12/04/2018
    FFR #8249 MK IV "Milano" Kit purchased 10/5/2018 - Graduated with 3.27 IRS, Multiport, Fuel Injected Supercharged 347 Big bore with Coil On Plug running Holley HP engine management, 576 RWHP, 510 Torque
    https://thefactoryfiveforum.com/showthread.php?29980 Milano thread
  17. Thanks Rebostar thanked for this post
  18. #16
    My wife was the one who wanted the shields installed after witnessing a fellow Mile-Hi Cobra Club member get bit on a club drive. Since she wanted them, I let her decide what to get. This is what she chose:
    They are subtle, and I get a lot of comments or people noticing them at shows.
  19. Thanks Rebostar thanked for this post
  20. #17
    I don't have them even though I've burned my leg a few times, but I'm not the smartest fellow.
    Please be advised that I do keep a small welding blanket in the car to protect Mrs. Go-Dad's legs.
  21. #18
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Mine are perforated, like RJD's above. They're from here. I bought them in bare steel and had them ceramic-coated satin black by Jet Hot, along with the side pipes, so they blend in pretty well and aren't that noticeable. I prefer the look of the side pipes without heat shields, but would rather my wife not burn her leg on the side pipes.
  22. Likes dalves liked this post
  23. #19
    Jun 2020
    Rising Sun , Md.
    I think they look good either way. I do not have any on mine for a little cleaner look, but I don't think they detract from the car.
    FFR 9883 MKIV ,427 Windsor engine
    TKX 5 speed, Three Link 3.55 gears
    Power Steering, Leather Seats
    18" Wheels and Tires, Drop Trunk
    Fun Package
  24. #20
    Jan 2024
    It turns out that Drummer Mike has a set of heat shields that have been ceramic coated in stock and ready to ship.. He recommended that I use these as I already have my side pipes ceramic coated and they'll match perfectly. When I get them I'll install and post the pics. Then I'll list the "cheese graters" I currently have installed in the parts for sale section of the forum.
  25. #21
    South Australia
    sell 'em to your local pizzeria
    Gen1 Coyote / TKO600 / IRS
  26. Likes Rebostar liked this post
  27. #22
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    I’ve tried to reach him a few times. Must have the wrong contact info. Would you pm me the contact info?
    Dan
    Current BOM
  28. #23
    Jun 2022
    I got the finish line set, everything works and looks great minus one fitting on one strap arrived lose and I can't tighten the bolt for it, and they're not answering phone calls or emails. I'm going to experiment with getting that fitting tight but haven't had a chance yet.
    MKIV Roadster - Complete Kit - Delivery 10/12/23
    Jan 2024
    I took the "cheese graters" off yesterday. They now reside in the "for sale" section. The Post Office tells me the set from Drummer Mike will arrive tomorrow. Pics to follow.
  30. #25
    Dec 2021
    Flower Mound TX
    It looks so much better without those.
  31. #26
    Senior Member Norm B's Avatar
    I have the cheese grater and like the look. They also give me some peace of mind when my wife is getting in and out of the car. I had to change the mounting hardware to fit where I wanted to mount it and re-weld the studs.
  32. #27
    Jan 2024
    Drummer Mike's heat shields arrived yesterday afternoon. I put the Cobra on the lift to make it easier to install the new heat shields. Pretty straight forward installation. Very high quality. These were the only ones I found ceramic coated ready to ship. The coating matched the side pipes exactly, which was a concern when I ordered them, but not to worry. I really love the "no visible means of support". Hats off to Mike. We got a break in the rain for a few hours so I pulled the car out of the shop to get some idea of how the shields would look in the sun.
    DSC03915.JPGDSC03916.JPGDSC03917.JPGDSC03918.JPGDSC03919.JPGDSC03920.JPGDSC03921.JPGDSC03922.JPGDSC03923.JPGDSC03924.JPG
  33. Likes jrcuz liked this post
  34. #28
    Feb 2022
    Flower Mound, TX
    They look great.
  35. Thanks Rebostar thanked for this post
  36. #29
    St. Louis, MO
    They look good, I've enjoyed mine for 12+ years and they still look great! I got the polished SS and they always shine back up.
    FYI: Make sure you get those straps securely tightened (I mean crank them down). One of my straps came loose in the first 100 miles and the shield came loose and fell down. I was REALLY LUCKY there was no damage! Just a PSA for you.
  37. Thanks Rebostar thanked for this post
