Results 1 to 3 of 3
Thread: Starter Wiring Question: Carbed 302 with Ron Francis Harness
    Senior Member Jim Doak's Avatar
    Midway, Utah
    OK, I'm currently working on wiring my car, specifically the starter. However, neither the FFR/Ron Francis wiring instructions nor the Tuff Stuff wiring instructions/diagrams are very detailed.
    I "think" I know what I'm supposed to do but I'd like some confirmation from the folks who've already been down this path.
    I've attached some photos showing the starter, the Ron Francis wires in the harness to the starter, the Tuff Stuff wiring diagram, and the 12 GA Tuff Stuff wire provided with the starter.
    I assume that the three Red wires in the Ron Francis harness all land on the upper terminal/lug on the starter solenoid? And that the Blue wire from the ignition switch replaces the "trigger" wire provided from Tuff Stuff that was designed to energize the starter using an old-style Ford starter solenoid/relay?
    Let me know what you think.
    Thanks.
    Mark 1 GUMBALL sold September 2019 with 46.6K-miles.
    Mark 4 GUMBALL2 retirement project commenced August 2024. Build thread: https://thefactoryfiveforum.com/show...2-Build-Thread
    Yes, that is correct, your battery lead also to the top terminal.
  3. Thanks Jim Doak thanked for this post
    Midway, Utah
    That's what I thought.
    Thanks, Rich.
