Some info on the 289 with pin drive wheels
For those pondering ordering a 289 kit intending to install pin drive wheels, here's what I've experienced with mine so far:
I originally ordered a 289 kit, only comes as a complete kit. Then I decided I wanted the Trigo pin drive FIA wheels, Chris at Trigo was very responsive and shipped me a set very quickly. The wheels, hubs and spinners are very high quality and look great. Chris mentioned I would need the shortened Moser axle, so I called FFR and they were happy to change my original order of the 3 link Moser to a shortened 3 link Moser. The MOSER axle is an excellent value because it comes fully prepared for the 3 link setup - just bolt it up and go. The 11.65" rear brakes fit fine inside the Trigos.
Can't use the IRS rear with pin drives because they can't provide the shortened axles. That's OK because I had planned on the 3 link anyhow.
I didn't realize I would have to order shortened from LCA's until after the kit arrived. So, I called FFR and they were happy to exchange my standard front LCA's for the shorter LCA's for the pin drives.
Installing the axle and front suspension went fine, I did have to cut about .5" off the wheel studs on each hub to allow for the drive pins, but that only cut off the un-threaded portion of the wheel stud - so less unsprung weight
I ordered the power steering rack and it was a tight fit, but I got it in. I had to cut about an inch off the tie-rod threads of the rack to allow for the shorter front distance between the tie-rods because of the shorter LCA's.
Otherwise, it went very smoothly, did a rough alignment and all is within specs with plenty of adjustment remaining. So, if you are considering pin drives for your 289 - do it! I used the same size tires Erik Treves used for his Black Mamba.
Jim Phoenix
Coupe-R delivered 8/10/2024
289 USRRC, F5R1011063RD - delivered same day
Coupe-R has a Ford Performance 363 mated to a TKX, 18084.
Many details on my Coupe-R are different from a typical Coupe build because mine is not street legal, race only.
289 has a BP 302 mated to a TKX 18084.
"For a little more, you can do it yourself." - Ed Hollingsworth... 6-Pack forums
Jim,
I've got the same set up as you except Factory Five shipped SN95 spindles and their adapter to mount them to the upper control arm. I'm going to need to have the couplings of the upper control arm shortened because my wheels are cambered out at the top and I'm out of adjustment. I was thinking just machine the shoulder off on both sides and that will give me enough room. Does anyone have any thoughts or experience with this?
Mike_T
Jim,
I saw a thread earlier in this forum that discussed shortening the upper arm links to accommodate the shorter lower LCA’s and get the -.5 degree camber. I didn’t have to shorten mine, but they are very close to bottoming out. I may have to shorten the rear links when I do the final alignment, but looks like it will be ok.
Jim Phoenix
Nice work! Your build thread is really interesting to watch.. Scouring the internet, it seems the general understanding is that you need to run the SN95 spindles with pin-drive front width suspension. It appears that you are running the 2-piece spindles with no problems, is that correct? I was originally sent the 2-piece spindles in my kit, but when I let them know what was shipped, they sent me the SN95s to use with the adapters (which is what is on my car at the moment). I'd be curious if I can shift over to the 2-piece spindles instead.
7litergt
Yes, I'm using the 2-piece spindles, they appear to be fine. -I can get the .5 degree of camber and 7 degrees of caster no problem. If I need more camber, I can simply shorten the upper control arm links, but doesn't look like that's necessary. I measured front track at 57", rear track at 58.5" as specified - so the front track appears to be about 1.5" short, but not sure that makes a difference and may be related to tire size.
Dan at FFR didn't mention having to use the SN95 spindles when I requested the shorter LCA's, so must be OK?
Jim Phoenix
One more question for you... It sounds like you have gotten to the point in your build where you have the static alignment setup where you like it. Are you noticing any positive camber gain under compression?
I went ahead and swapped over to the two-piece style spindles on my build over the past weekend (as well as changing out the ball joints to some Moog units), and was very pleased with the assembly. I got the chassis down on the tires at ride height (just under 5" to the ground) and when I set more weight in the car to simulate some compression I can see the tops of the tires moving outward. Its not a ton, but enough to notice... I figured I would check if you are seeing the same thing on yours? I realize there are limitations to the packaging on this front suspension, so I dont know how much of a camber change is normal.
Not a waxer
7litergt
Caster has a big effect on camber change.
7litergt
I plan to put the car on the ground later this weekend, but first I plan to replace the right front spring as I just received the correct 500# spring from FFR. I’ll check the steering and alignment again. Right now it’s up in the air and it has a lot of negative camber, as I lower it, I’ve seen it settled and end up at -.5 degrees, so the suspension does move the camber positive as the car squats down on its suspension. I suspect if I set the camber at ride height, it will go slightly positive depending on how low the car dives under braking.
Jim Phoenix
I realize this thread is a few months old.
When I ordered my 289 kit I let them know that I wanted to use pin drive wheels from vintage wheels. I also wanted IRS. I ordered my kit to take advantage of the free powder coating and free wheel sale Because there was no end date posted to the sale and I didn't want to miss it. I wanted the wider wheels for the back as most everyone does but I was told they would not ship the 7 inch wheels and the 10 inch wheels together because the kit comes with 4 7 inch Halibrand wheels and that's what I was going to get. I figured I'd sell those wheels to help put a dent in my pin drive wheels.
Of course I found out much further down the road that I needed the short LCAs as well as the adapter AND I needed to use SN95 spindles. OK. Would've been pretty awesome to know upfront to help me plan and spend a heck of a lot less money than I ended up spending. I was very fortunate through a friend to find the SN95 spindles.
Any pin drive wheels I've seen have a backspacing of 3.7 inches. Vintage wheels will make custom backspacing for an additional fee so that's what I did to get what I wanted.
So my 289 will have IRS, and the correct style pin drive wheels, because as I always say, my car, my way.
I wish FF had been a bit more flexible with me, especially when buying a kit after flipping my Mk1 and living to tell the tale, but in the end, it's all good and I'll have a 289 the way I want it and hopefully enjoy for years to come.
For anyone considering IRS and custom backspace pin drive wheels from vintage wheels, the cost is $450 per wheel and the gentleman that does this for them is or has retired and I don't know what their plan is going forward for those who need custom backspacing.
Mark
Gone but not forgotten. Mk1, Frame #1929 Complete restoration/upgrade.
