AC Cobra pedals installed. Here is my how to:
https://youtu.be/LtMVh14eKg8?si=UCkqjJArhibT4NA0
FFR3490 - MK2 Roadster: Yellow with black stripes, mildly built 5.0 with many upgrades/updates to come.
See my build here: https://youtube.com/playlist?list=PL...6mVHNS3FsRV76S
Adding defrost vents and more prep for final dash install.
https://youtu.be/Q66AHhBVSG4?si=igZextf6t4-DEXBx
Almost time to put the dash in. Defrost is done, last bits of wiring done, and more cutting/adding clearance with the frame/body.
https://youtu.be/2BkpXYod_N8?si=T7uZbgFOeUJWmaeK
I thought I would have the dash in today. Last minute change for safety/reliability changed that.
https://youtu.be/HiqUAzKL98s?si=iEgR0q6ZEGHuUAvW
Finally, the dash is in!
https://youtu.be/pIcfXAD6O20?si=6fE5QccoWwk3NzXe
A little setback in getting my car back together.
https://youtu.be/Wb-O5flIVt0?si=h4Pe-Rku4qNnPhVT
Back on track after my setback. Things are coming together.
https://youtu.be/sB8y5_Snhck?si=uQlpnbBQnuMfUHlD
Finally done with wiring, but now have a new fitment issue with the custom dash.
https://youtu.be/Tk7izsm3GkM?si=O0v0JrzvbyN47GKP
Finally done with the custom S/C dash install.
https://youtu.be/6Dp9rbdKLdg?si=gMQtzO-nqEq674qD
Took the time to customize the Factory Five dash brace and make it look like a real Cobra. Very happy with the results. Here is what I did.
https://youtu.be/dS7kNKtj8v0?si=wRsBzUMLlACwIUJC
Now that the interior work is done it’s time to tear down the engine and save some weight while gaining some performance by installing new heads.
https://youtu.be/-Dkju9Gx1Bg?si=Jd5goMglJTskKLR0
Update on the Cobra, starting the prep and cleanup for my new heads that are going in. Full walkthrough of parts being used as well as the weight savings.
https://youtu.be/3X2azFYSOo0?si=o6-1BV2bdmITfeKw
Overview of all of the required prep before installing the new Trick Flow heads.
https://youtu.be/1uHN2ySR8LU?si=y9AsaRNRRCoOzPBn
The heads are on! More progress on my Cobra.
https://youtu.be/jT9FzTexRqU?si=yjK5kzkNc8g6mQTL
More ground made, full valvetrain install with lash setup procedures and installed the intake manifold.
https://youtu.be/szBe5ceOpbk?si=TkyrSq6g3PONOaUB
More ground made on getting the engine back together. That much closer to the first fire with all the upgrades.
https://youtu.be/hqtFkDn9Kp8?si=fkETvJOcK8LKlRw6
Making up more ground with getting this back together. I’d say 1st start is only a week or 2 away. Getting close!
https://youtu.be/mxYGzfyojg0?si=UDhEeKzYFfqQeWl2
The engine assembly is finally done. Next up, first start after I set up the Edelbrock Pro Flo 4 ECU.
https://youtu.be/eKrdryaEIk8?si=KwFdCjTMtFfsJOO_
After well over a year, my Cobra is finally running again after significant re-work.
https://youtu.be/TcWRJGWxUuQ?si=aY33wzm8Sy71dUCn
Time to get things ready to drive this car. Fixed the tune to get it running better and working on making it road-worthy.
https://youtu.be/IKGpPlTsafE?si=1mBtXIrFrkYA9_Gm
She’s back on the road! Wrapped up the last few things then took it for a test drive included in this video.
https://youtu.be/NeQ93JklQQk?si=xkgWkhhjPv2ZLsBb
After about 100 miles of break in driving, I had a part failure. Fixed the problem and started some new upgrades.
https://youtu.be/A7tsOe525Qo?si=vmWyW3SWBX_Z3yA9
Starting to be able to really enjoy the car now. New tires, more car shows, and continuing with cleaning things up.
https://youtu.be/f70vFhkRL-s?si=l0sWiBjPJrX7YnSe
More work on the Cobra. Sunvisors, engine bay cleanup, and some show pics.
https://youtu.be/V0NT2hwReco?si=h6R62QgeTeGXabMF
Long overdue update on my MK2 Cobra. Small issues/problems that have popped up and working on tuning the Edelbrock ProFlow 4 EFI.
https://youtu.be/vuEHCYO5ux8?si=KN502ZoDyt8Oxye2
Went to a show and won a trophy.
https://youtu.be/11dJLSGMa_M
End of season updates on the Cobra and upgrade plans for the off season.
https://youtu.be/xMWD86S0U7o?si=jWMqAA5d_SM0ZXrC
Finally time to tackle the suspension updates. Starting in the rear with coilovers and aluminum control arms.
https://youtu.be/Y9CcTZXT4r0?si=7RoEEXLWxC-u1Zcq
Hey, just started working through your videos. Great stuff so far!
I find this type of work really interesting. I’m currently resurrecting a partially started or partially finished or partially built Mk3. Whatever the case, I basically ripped apart and rebuilt it.
Thanks for documenting your progress.
Back to work on the Cobra. Replaced the lower arms with Steeda aluminum arms and started the coil over install including adjusting the Koni reds.
https://youtu.be/SrJWBgsspr4?si=6IHrHkcnz8sfs8Ci
More progress made on the rear suspension, and a few more issues popped up in the process.
https://youtu.be/MlFyHamOYA8?si=xM6mehhdCtnAUHOX
