![Midwest Classic Insurance](https://thefactoryfiveforum.com/attachment.php?attachmentid=40531&d=1428867682)
0
0
WTB: MK3.1 or MK4 parts
Good day all!
I'm working on building an MK3.1 Roadster. I need the following parts if anyone has them, please let me know.
Todd
Still needed
14675 KONI SOLID AXLE REAR COIL OVER KIT
15414 FRONT UPPER CONTROL ARM WELD-ON RETROFIT KIT
16285 11.65" SOLID AXLE REAR BRAKES
17460 ELECTRICAL COMPLETION KIT W/ HARNESS
14166 2" POWDERCOATED ROLL BAR
15074 MK4 COMPLETE ASSEMBLY MANUAL (PAPER COPY)
BRAKE MASTER CYLINDER
PEDAL ASSEMBLY (CLUTCH & BRAKE)
Purchased and no longer needed
12077 SEAT TRACK KIT
14676 KONI FRONT COIL OVER KIT
14850 MK4 TWO PIECE SPINDLES
12066 FRONT LOWER CONTROL ARMS
Reason: more updates to the updated list
I have the rear brake kit (rotors, calipers and pads) for the IRS setup, and the driver's seat track kit. Not sure it'll fit your solid axle setup. You can have all of it, free of charge. Shipping is a bit of a bear. I know this, because I shipped my front set to a forum member a year ago, and shipping was $150. I see you are in Iowa; if you're willing to drive to KC, you can pick it all up, no charge. Otherwise, I'll have to ship to you. The rear calipers I have are painted black.
Greg
Bump, I updated list of parts still needed.
![LCD Gauge Systems](https://thefactoryfiveforum.com/attachment.php?attachmentid=207714&d=1734617469)
