Thread: Fitting the doors
    Feb 2023
    Fitting the doors
    Is it really necessary to put on the windshield before fitting and aligning the doors? We have a friend who built two, never did and had no problems.
    Cleve
    O'Fallon, MO
    No, not necessary, it has nothing to do with door fitment
    I disagree. It all works together. I rough install all the big parts then start fine tuning everything. The windshield can press down on the body causing to bulge out a bit on the sides and changing the way the doors fit.
    Falmouth, MA
    I agree with Mike that the windsheild should be in place before fitting the doors. Dis one without the windsheild and had a ***** time getting the drivers door to fit correctly afterward. Had to remove door, redo jamb, door and repaint.
    O'Fallon, MO
    I have never had the windshield alter the shape enough to be an issue, but it's not a big deal to have it in place.
  6. Likes Mike.Bray liked this post
    Apr 2024
    I would recommend putting in the mud flaps, debris shield aluminum with bulb seal, at least with clecos. I had my doors dialed in but waited to put those parts in until after it was painted. It pushed the body out from where i had it just enough on the drivers side to warrant a minor adjustment of the hinge.
    Mk4 Complete Kit 11037. Ordered 03/26/24 Delivered 05/29/24 Complete 1/7/25. Powdercoat, IRS, Gen 1 Coyote Donor, North Racecar AC
    Feb 2023
    Again thanks everyone for replyng. Much appreciated.
