I have BBK headers and am using the single 3 in. side pipes. They are extremely loud and would like to add resonators to the side pipes? Any recommendations would be greatly appreciated.
Cleve
Cleve
I've been researching this a bit. They make auger style inserts for the side pipes. Maybe check out this link as a starter: https://www.ffcars.com/threads/flexi...90847/#replies
There are lots of options on Jegs, summit, etc.
Build 1: Type 65 Coupe
- Album: Coupe Album
- Delivered: February 24, 2022, Legal: April 20, 2024, Complete: TBD
Build 2: Mk3 Roadster (Acquired as a partially started build)
- Build Thread: TTimmy’s MK3 Basket Case Build Thread - Album: Mk3 Album
- Originally Delivered: 2004, Acquired by me: August 2024
I purchased custom mufflers from chamfered exhaust and welded them in.
Build Thread #1 https://thefactoryfiveforum.com/show...been-delivered
Build 2 MK4 #11061- Delivered 08/24/24
Build Thread #2 https://thefactoryfiveforum.com/show...006#post562006
Let me start by saying this fix isn’t for everybody. First I have just plain painted side pipes with solid stainless heat shields. What I did to quiet them down a little is picked up some under car header turn downs and glass pack inserts that slip inside them. Don’t remember exact dimensions but believe the inserts are 10 or 12 in long. The the turn downs are sized to slip over and clamp to the outlet pipe of the side pipes after the turn out is cut off. This basically adds a resonator and allows for the turn out to be positioned so it’s not pointing straight out but anywhere from there to straight down. I put mine at about a 45 which also helps slightly more with the noise in the cockpit. In my case the heat shields cover the clamp so it can’t be seen. This set up is also a little longer so puts the outlet back close to the rear fender which I suppose might add to the lessening of noise another slight bit. I did this mod quite sometime ago so don’t now what’s available these days for materials so you’d need to measure check suppliers.
