Thanks Thanks:  5
Likes Likes:  7
Thread: Door Larch "Fix"
    Nov 2023
    Western South Carolina
    Door Larch "Fix"
    Well, I'm just a retired working class guy, I like to save a buck when I can. I replaced the door latch TWICE and, of course, you can't just buy the latch you need....you have to buy a PAIR. Part of the problem was the door itself (alignment), I should have addressed that before now. This time I have addressed it and the door opens and closes like butter. With the latch mechanism itself, what I don't like is that the operating lever is held on the rotating "shaft" by a peening process. In both failures, the lever popped off the peened end of the "shaft". This "shaft" has a square hole thru the center. After measuring this square hole, I determined that a 7/16 course thread could be tapped. Then I got a 7-16-14 FULL THREAD bolt, cut it to the proper length so that the end is flush when installed, and then installed it with red loctite. Just saLatch.jpgved myself $130.
  2. Likes tnt_motorsports, StangRacer, TTimmy liked this post
    The door latch's have a long history of failure. I believe it was back around 15 years ago that a suggestion on a simple fix similar to yours was first suggested.
    I learned early on that being gentle on latching the door closed by using the lever, rather than slamming them shut, could help with preventing their failure. No fix needed as of yet, fifteen years and counting.
  4. Thanks ProfessorB thanked for this post
    Likes ProfessorB liked this post
  5. #3
    Search 'Wade's door latch fix' from 15 yrs ago. He did the same thing. I also throw away the little tension spring that hooks onto the release lever. The enclosed spring is fine on it's own.
  6. Thanks ProfessorB thanked for this post
  7. #4
    Senior Member Norm B's Avatar
    The Forum search function doesn’t work very well. Try using Google with “FFR roadster” plus the issue you’re having in the search. All kinds of results will show including stuff posted on the other forum.
    Norm
  8. Thanks ProfessorB thanked for this post
  9. #5
    Nov 2023
    Here's kid of a generic question: I wanted to "like" and "thank" all these responses but can't seem to figure out how. Can somebody tell me how? I click on the little box to the right of the words "Post thanks/Like" and it just seems to give me the history. What am I doing wrog?
  10. Thanks AndrewIdaho thanked for this post
  11. #6
    Feb 2024
    Outside Boise Idaho
    Quote Originally Posted by ProfessorB View Post
    Hello Professor
    Just below the post is a ribbon with title Post Thanks .... followed by a smiley face button and a thumbs up button. Press Smiley to thank and thumbs up to like.
    Andrew
  12. Thanks ProfessorB thanked for this post
  13. #7
    O'Fallon, MO
    I have no idea what a door larch is?
