Thanks Thanks:  6
Likes Likes:  51
Page 2 of 2 FirstFirst 12
Results 41 to 70 of 70
Thread: Chassis number 1340
    Jun 2020
    SoDak
    On Gen2 with full fenders/running boards you need to use the bottom holes.
    Jim
  2. Thanks Ltfracing thanked for this post
    Likes Ltfracing liked this post
  3. #42
    Jul 2020
    Spencer, MA
    Lower holes for full fenders and trucks. Upper holes for no fenders or bike fenders. NOTE: If you go with the lower holes there is no going back as you need to cut the top of the rearmost lower control arm mounting bracket to have enough clearance for the steering rack. It's in the build manual. It's a personal choice though if your not using full fenders. More rear tire clearance, although adjustable with the coil overs, and more road to frame, or exhaust, clearance. I chose the lower holes, potholes and speed bumps, to save the cats which are round and hang some what low.
  4. Thanks Ltfracing thanked for this post
  5. #43
    Senior Member Ltfracing's Avatar
    Aug 2022
    Moving steering shaft over to the right 3 inches to straighten funky angles out and moving brake pedal over to where clutch pedal would be
    33 hot rod,383 sbc tri power setup ,700 r4 transmission,gen1 body gen2 chassis
  6. #44
    Aug 2022
  7. Likes Just 1 More liked this post
  8. #45
    Sep 2022
    Huntington, IN
    Looks like you had a busy weekend
  9. Likes Ltfracing liked this post
  10. #46
    Aug 2022
    Got my block hugger headers in
  11. Likes RoadRacer, Mastertech5 liked this post
  12. #47
    Aug 2022
  13. Likes TxMike64, Mastertech5 liked this post
  14. #48
    Aug 2022
  15. Likes TxMike64 liked this post
  16. #49
    Senior Member Tom Veale's Avatar
    Wisconsin
    Hi LTF, Re: Mounting bolts for Shocks at Front End................
    It's best to have the NUT nearest the radiator not the bolt head. When it comes time to change things, you don't want to have to move the radiator to get the bolts out.
    Once you put the Fan Shroud and fan in place it gets pretty crowded around those fasteners.
    (I learned this from experience!)
    Best wishes,
    Tom
  17. Likes FF33rod, JimLev liked this post
  18. #50
    Aug 2022
    From building race cars my whole life all bolts go front to back ,it’s a hard habit to break,if nut falls off bolt will not come out with car moving forward
  19. Thanks Tom Veale thanked for this post
  20. #51
    Jul 2020
    Spencer, MA
    When did you get the grill? Looks good!
  21. Likes Ltfracing liked this post
  22. #52
    Aug 2022
    Just got it the other day,thank you sir
  23. #53
    Aug 2022
  24. Likes Just 1 More liked this post
  25. #54
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Ltfracing View Post
    Love the tear drops in the fenders
  26. Thanks Ltfracing thanked for this post
  27. #55
    Simi Valley, CA
    taillight options
    I got these from Speedway for my '33: https://www.speedwaymotors.com/Speed...ghts,8978.html
    Keith HR #894
  28. Likes Ltfracing liked this post
  29. #56
    Aug 2022
    Sold the tunnel ram, Was gonna put a cross ram on it, ended up getting a Tri Power set up which I’m rebuilding now
  30. Likes Just 1 More liked this post
  31. #57
    Aug 2022
    IMG_7558.jpg[ATTACH=CONFIG]208969[/ATTACHIMG_7558.jpg
    Getting ready to paint the chassis
  32. #58
    May 2018
    Pinckney, MI
    I had the same idea...
    - Peterh226
    35 Hot Rod Truck (Ext) Delivered 11/21/24
    33 Hot Rod Gen 2 #1134 ~1400 miles
    54 Pontiac Star Chief
    05 F-150
  33. Thanks Ltfracing thanked for this post
  34. #59
    Aug 2022
    Beautiful car sir
  35. #60
    Aug 2022
  36. Likes Just 1 More, FF33rod liked this post
  37. #61
    Aug 2022
    Got my new rear lower arms,also got ride of all the rubber bushings in the front suspension
  38. #62
    Aug 2022
  39. #63
    Kingsland, TX
    Are you using different ratio rockers for Int/Exh?
  40. #64
    Aug 2022
    Yes sir
  41. #65
    Aug 2022
  42. #66
    Kingsland, TX
    That's interesting! I've never seen such a big difference between int/exh before (granted, I don't have a ton of cam spec experience). I've seem slight differences, and split durations, but that's like two different cams put together. What's the advantage?
  43. #67
    Aug 2022
    Tourque,nice flat curve
    Custom ground by my friend at Koury racing engines
  44. Likes TxMike64 liked this post
  45. #68
    Aug 2022
    Chassis goes for paint next week,then I can drop the heart in
  46. Likes FF33rod, Just 1 More liked this post
  47. #69
    May 2013
    OH,KY,WV tri-state area
    No lock plate for the cam bolts??
  48. #70
    Aug 2022
    Red loctite
