Results 1 to 9 of 9
Thread: My Donor Car
    Jan 2018
    My Donor Car
    Well.. The process of building a Factory Five car has begun. I'm not sure my wife understands what I'm trying to do (though she is incredibly tolerant of me and deserves a new piece of jewelry). My kids just think of this as a fun project.
    I've attached a picture of my donor car. It's a 1999 Ford Explorer 5.0L. I bought it at a Copart auction for $350, excluding taxes and fees. I have a daily commute of about 40 miles total each day. So my plan was to drive it for the next 6 months while I get ready to purchase and receive my kit, as well as all the planning I need/want to do.
    I took the donor car down to my local Firestone Auto and asked them to give it a complete inspection and report back. Amazingly, the car is in really good condition to have 262,000 miles on it. Here are some the major quirks:
    1. rear main seal leak, seems normal and expected considering the mileage
    2. front seal leak on the differential, ditto #1
    3. differential cover leak, ditto #1
    Here's my plan for the next 6 months:
    1. Drive her daily for the next 6 months
    2. Figure out the differential/rear end. This Ford Explorer read end has 3.73 gearing, 8.8 " spacing. I'm hoping to use it for my kit
    3. Engine (Plan to rebuild it myself as I've always wanted to do this)
      • target specs after rebuild - 300-350 HP, 350+ (ft-lb) torque ?
      • locally who is going to do my engine machine work (those folks are starting to retire and the market demand is just not what it once was)
      • what transmission am I going to use
      • plan to use an Isky cam
      • refresh the GT40P heads w/ some light porting work, roller lifters, valve spring upgrades
      • replace all the bearings internally
      • hope that I don't have cylinder work to be done, won't know until I open up the engine
    4. Need to get the garage ready for all the boxes I'll need to keep
    One of the best things I've done is pay $20 to someone on EBay and purchased the Ford Service Manual. It provides ALL the details, i.e. torque specs, how to remove the engine, how to rebuild the engine, etc. Simply awesome.
    I'm open to comments, suggestions or things to avoid, so let me know what you think.
    -brad w.
    Welcome! The Explorer rear end won’t work but the engine long block can be used.
    Jan 2018
    What's the issue with the Explorer read end? Is it because the center section is offset?
    That, the overall width and the lack of the proper control arm mounts.
    Jan 2018
    Thanks for the insight. I'm having a real difficult time finding details and references to things like "overall width" and etc..
    Lilburn, GA
    Rear end widths. You want the 59.5" width if possible.
    Mustang 8.8 (ring gear size) Rear End widths per year
    1987-1993 - 59.5" Width
    1994-1998 - 60.8" Width
    1999-2004 - 61.25" Width
    May 2013
    OH,KY,WV tri-state area
    Like the other mentioned that axle housing won't fit the FFR car. However. Keep the axle gears and carrier (Part the ring gear bolts to) THey fit other 8.8s Most all OEM mustang axles Did NOT come with a 373 gears but usually 2.73 or 3.08
    Feb 2020
    Virginia
    When selecting headers to use be aware the GT40P has a different spark plug angle than GT40's or E7's. You can usually get by with 90 degree plug wire terminals and/or shorter "header plugs". Not that big of a deal but just something to keep in mind...
    Also, with 262,000 miles the rear seal surface of the crank probably has a groove worn in it from the rear main seal. You can get a repair sleeve from Fel-Pro, IRRC... You can buy the installation tool for the sleeve or have the machine shop install it when they check the crank. Again, not that big of a deal but something to be aware of...
    Norton, MA USA earth
    Sell it when your ready to build and use the money towards a new engine.
  10. Likes JeffP liked this post
