Gen 3 Coupe FFR Door Opening Latch Reliability & Operability Questions
I have a question or two regarding the Gen 3 Coupe plastic Door Opening Latch.
How reliable is it from either the plastic latch housing breaking or the swagged-on cable end piece from slipping off and thus the door being inoperable?
For one, it would be an extreme bummer or worse if either would malfunction, with the door closed and the result being the door unable to be opened.
It's one thing to be outside the car trying to get in, but with the FFR Gen 3 Coupe door window frame installed, it might be next to impossible to exit the car, particularly in urgency!!
Before I assembled the door window frame assembly, I didn't check to see whether my body could even fit thru the window-frame opening.
While I haven't experienced any such failures, the door handle latch on my coupe seems to vary from easy to actuate to difficult depending on driver vs passenger side and possible nearing the limits of latch strength.
Has anyone experienced any breakage? Might the FFR metal version be an improvement?
Any insights?
Bob - I am curious about this post. Not to reiterate a back and forth conversation with another member but I had asked him where he got his billet door handles from. He stated he ordered them with his kit. I have been unsuccessful in locating them on FFR's parts site but regardless, during the conversation, I had said something about not wanting to put plastic door handles in and he said his factory originals were aluminum and powder coated black. I had not opened mine during inventory but went back and checked and sure enough they are metal. So maybe your concern is simply a matter of upgrading your door openers? Not necessarily to the billet ones but the standard new issue.
If your real concerned, make the door panel removeable so you can trip the latch by reaching inside the door pocket
Consider adding some door poppers. They are an inexpensive and easy mod and will give you a solid “plan b” in case your manual opener fails. There is plenty of room inside the door cavity. And people really dig them!
East Coast Speed Machines
7 years - 11,000+ miles on the plastic handles - I think I may have adjusted the cables once....plastic handles are still the originals --- I added door poppers at about 5000 miles.
Lube them up. Mine vary too, but they’re completely dry, once you put some actual lithium grease it should make it infinitely easier.
My experience installing those poppers is they don’t like that angle. Installed horizontal on the top rail and they pull straight back effortlessly.
Bob Brandle
As I can, I'll try lubricating the door capture latch mechanism.
Bob, that helped me a lot on my build. Door latch was much easier to use once it was lubricated
Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21, CA SB100 Registered 8/27/24 - BluePrint GM 427 LS T56, IRS, AC, Power Steering.
Album Here
I think I have your solution
I think this is what my kit came with. They are aluminum alloy and seem to be of good quality.
Checkout this Southco model AC-75-101-11. They have CAD drawings on the site so you should be able to work out whether this will be a direct replacement.
https://southco.com/en_us_int/ac-75-101-11
Build 1: Type 65 Coupe
Album: Coupe Album
Delivered: February 24, 2022,
Legal: April 20, 2024,
Complete: TBD
Build 2: Mk3 Roadster (Acquired as a partially started build)
- Build Thread: TTimmy’s MK3 Basket Case Build Thread - Album: Mk3 Album
Originally Delivered: 2004,
Acquired by me: August 2024
