Thanks Thanks:  6
Likes Likes:  2
Results 1 to 8 of 8
Thread: Seat Heaters
    Senior Member MaxVmo's Avatar
    May 2023
    Seat Heaters
    Hi all, have decided to install seat heat. Anyone have a favorite?
    BUILD in progress:
    MKIV delivered Sept 2023 BPE 347 Tremec Five Speed
    First start https://m.youtube.com/watch?v=GHb0v2GtFk0
    Woodstock ,Illinois
    From Forte! For ease of installation, I ran 12 volts to the seat location, tucked all the control wiring in the seat and put the switch on the front of the seat bracket. It's easy to get to and doesn't clutter the dash.
  3. Thanks MaxVmo thanked for this post
    Likes Nigel Allen liked this post
    Dublin, OH
    got mine from cobra heat. I think Mike Forte sells them too.
    Easy to install. Just need to figure out your wiring and switch placement.
  5. Thanks MaxVmo thanked for this post
  6. #4
    Dec 2021
    Flower Mound TX
    Forte
  7. Thanks MaxVmo thanked for this post
  8. #5
    Senior Member Rebostar's Avatar
    Jan 2024
    Got mine from Summit, thay are made by Dorman. They come with the switches and relays all pre-wired. Simple installation instructions. The switches have a high and low setting. They look and work great. https://www.summitracing.com/parts/RNB-628-040
  9. Thanks MaxVmo thanked for this post
  10. #6
    Senior Member TTimmy's Avatar
    Sep 2021
    Emmaus, PA
    I used some generic Dorman units. I simply ran power to the seats and installed the switches and other bits into the seat assembly. I did this for both of my builds.
    Here’s what I did… This may help:
    https://thefactoryfiveforum.com/show...l=1#post572026
    Build 1: Type 65 Coupe
    - Album: Coupe Album
    - Delivered: February 24, 2022, Legal: April 20, 2024, Complete: TBD
    Build 2: Mk3 Roadster
    (Acquired as a partially started build)
    - Build Thread: TTimmy’s MK3 Basket Case Build Thread - Album: Mk3 Album
    - Originally Delivered: 2004, Acquired by me: August 2024
  11. Thanks MaxVmo thanked for this post
    Likes steno liked this post
  12. #7
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    Warmseats Seat Heaters from Cobraheat - https://cobraheat.3dcartstores.com/W...ater-_p_9.html
  13. Thanks MaxVmo thanked for this post
  14. #8
    May 2023
    Thank you all. I have an unused heater power source wire—thinking of this for power.
    BUILD in progress:
