Results 1 to 2 of 2
Thread: Factory Five Cobra Wheels/Avon Tires
    Member dagall's Avatar
    Ocoee, FL
    Factory Five 15 inch Halibrand replica wheels with Avon tires. The tires were on my Mark 1 and have about 1k miles on them and were purchased about 2 years ago. The tires ride nice and they are quiet. If you were in London, OH you may have seen them on my car. The wheels are F5 specs; 15x8 and 15x9; Front backspace is 5" and the rear is 5.48" with Ford bolt pattern. The tires are 225/60 and 295/50. I have had the rims on the car for some time but they are in great shape. I am selling these due to the upgrades made on my car and I went with the 17's. You would have to purchase two sets of spinners from F5 as I am reusing two for the 17's.
    Asking $2800 or best offer. I am in Orlando, FL so I think PICK-UP is best rather than shipping these out. Send me your email and I can send a couple more pictures. I won't let me delete previous photos posted.
    This truly authentic 15" 5-lug bolt on wheel incorporates an innovative cosmetic cover and machined knock-off and spinner design. This feature gives an extremely authentic and quality appearance while maintaining the safety of a modern DOT design.
    These wheels are cast aluminum, extremely strong, and lightweight. The centers are painted a beautiful metallic grey and the rims are polished. The entire wheel surface is then clear coated to protect the finish from oxidation. This is a one piece wheel designed exclusively for Factory Five Racing. The knock-off adapter, spinner, and cosmetic lug cover are also included. These wheels have backspace that optimizes the depth of the wheel dish while providing adequate clearance for Ford GT calipers and rotors.
    Technical Specifications:
    Wheel Set Part Number: 14867
    Front Wheel Size (Diameter x width): 15"x 8"
    Rear Wheel Size (Diameter x width): 15"x 9"
    Front Wheel Backspace: 5"
    Rear Wheel Backspace: 5.48"
    Wheel Lug Pattern: Ford style 5 lug x 4.5" bolt circle
    Material: Cast Aluminum
    Color: Gun Metal
    Weight with adapter, spinner and lug cover:
    15"x 8": 17.48 lb 15"x 9": 18.28 lb
    FFR Fitment Applications:
    Mk 1, 2, 3, and 4 Roadster
    65 Coupe
    Axle Applications:
    1979-1993 width Ford 8.8" solid axle
    FFR standard width IRS
    Front Brake Fitment: 11" 1999-2002 Mustang GT Calipers and Rotors 11" 87-93 Mustang GT Calipers and Rotors
    These will not fit 2003-04 GT Calipers
    Rear Brake Fitment:
    10.5" Rear disc brake kit
    11.65" Rear disc brake kit
    '33 Hotrod #448, HotRod Flat Black, Engine Turned Firewall,
    306, B-Cam, GT40p Heads, Shelby High Rise Intake, Dual Quad Holleys, Four Link 3.27
    FFR 2863, Arctic Silver w Blue Stripe, Lemans T-Top, 306, Ported Polished Heads, 600cfm Carb,
    QA1 Shocks, 3-Link, 17inch Wheels
    Ocoee, FL
    Anyone in Florida interested? Price to high? Avon’s are running over $600 each right now. You get rims and a set of tires for the price of just the tires.
