Hi all, have decided to install seat heat. Anyone have a favorite?
BUILD in progress:
MKIV delivered Sept 2023 BPE 347 Tremec Five Speed
First start https://m.youtube.com/watch?v=GHb0v2GtFk0
From Forte! For ease of installation, I ran 12 volts to the seat location, tucked all the control wiring in the seat and put the switch on the front of the seat bracket. It's easy to get to and doesn't clutter the dash.
got mine from cobra heat. I think Mike Forte sells them too.
Easy to install. Just need to figure out your wiring and switch placement.
Forte
Got mine from Summit, thay are made by Dorman. They come with the switches and relays all pre-wired. Simple installation instructions. The switches have a high and low setting. They look and work great. https://www.summitracing.com/parts/RNB-628-040
I used some generic Dorman units. I simply ran power to the seats and installed the switches and other bits into the seat assembly. I did this for both of my builds.
Here’s what I did… This may help:
https://thefactoryfiveforum.com/show...l=1#post572026
Build 1: Type 65 Coupe
- Album: Coupe Album
- Delivered: February 24, 2022, Legal: April 20, 2024, Complete: TBD
Build 2: Mk3 Roadster (Acquired as a partially started build)
- Build Thread: TTimmy’s MK3 Basket Case Build Thread - Album: Mk3 Album
- Originally Delivered: 2004, Acquired by me: August 2024
Warmseats Seat Heaters from Cobraheat - https://cobraheat.3dcartstores.com/W...ater-_p_9.html
Thank you all. I have an unused heater power source wire—thinking of this for power.
BUILD in progress:
