Summit SUM-300103-16 (56 Ounce) Tank?
I have seen in past post some say the have used this tank. Can Anyone weigh in or have pictures?
I like that it is SS so will be polished longer than the FFR one. Its larger volume wise than the FFR one and it still looks very similar while taking up a similar volume to the FFR.
https://www.summitracing.com/parts/sum-300103-16
Yes the Moroso, Canton, etc. are very nice pieces however don't seem to quite hit the mark on the above points quite as well.
Not a waxer
I’ve used it on at least 2 cars. No complaints.
Doc76 thanked for this post
Looks like the one I used on my car when the FFR one proved to be too small. Works great.
Same one I used with my 427. 5 years and 6,000+ miles and looks bright shiny and new. Go for it!
This is a recent picture of the Summit tank that is about 10 years old. Still shiny with no special attention to it over the years. Its no longer in use as I went with a closed system a number of years ago using a Moroso tank to better evacuate air from the left cylinder head. Its a Coyote thing you can see the small hose in the picture. Never bothered to take the Summit tank out.
Has anyone ran this one?
I’m unable to use the titled tank as planned.
Canton Racing Coolant Recovery/Overflow Catch/Fill Tanks 80-201R (it’s the round 2.5qt)
https://www.summitracing.com/parts/ctr-80-201r
You can't go wrong with Canton. I have two in my cooling system, but not that one. Canton operates an ebay store with open box and blemished product. You may be able to save some money.
