Results 1 to 3 of 3
Thread: Attention Daytona Wizards. Main fuse panel and refi to fuel pump.
    Apr 2022
    The manual says to cut the orange wire leading to the relay and tie your EFI FAN wire in here. Problem is the pic in the manual shows it being but BETWEEN the fuel pump fuse and relay. Isn't this a really bad fire hazard? Should it be cut before the fuse so the fuse and the relay are protected???
    What EFI setup are you using? There are several ways to wire in your EFI without modifying the fuse block wiring.
    Jul 2021
    Tonganoxie, KS
    Ditto what Papa said. I didn't modify my fuse panel to accomodate my ProFlo4 EFI setup.
