Results 1 to 5 of 5
Thread: Help with trailer/signal wiring
    Senior Member MaxVmo's Avatar
    May 2023
    So I’ve got a diagram for the wiring I found on the Forum. My question is (under the tank install), do I splice in before the Y at the tank? The diagram has a ground and tail light wire splitting after the flat box…I’m assuming I wire it in and then let the harness divide further at the Y?
    BUILD in progress:
    MKIV delivered Sept 2023 BPE 347 Tremec Five Speed
    First start https://m.youtube.com/watch?v=GHb0v2GtFk0
    Jul 2021
    Tonganoxie, KS
    Correct. I did essentially what you're doing, but further 'upstream'...I put the trailer adaptor behind the dash.
    Greg
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    I wired mine in the same location - you do need to wire it in before it splits to left and right sides.
  4. Thanks MaxVmo thanked for this post
    May 2023
    Greg
    Greg I’ve considered this—how exactly did you do it behind the dash?
    BUILD in progress:
    Jul 2021
    Tonganoxie, KS
    Quote Originally Posted by MaxVmo View Post
    Same as you do it near the rear...just closer to beginning of the rear harness section, where it connects to the main harness. No magic to it.
    Greg
