London Cobra Show
Thanks Thanks:  10
Likes Likes:  5
Results 1 to 19 of 19
Thread: Rear End Paint?
    Jul 2024
    BC, Canada
    Rear End Paint?
    Suggestions on a durable, brushable black paint for my rear end?
    Oct 2019
    Erin, Ontario CANADA
    My vote is for POR15.
    Earl
  3. Thanks Doc76 thanked for this post
    Member Carography's Avatar
    Marysville, WA
    X2 por15
    Marysville, WA
    302, GT40 heads, 5speed, 3.55:1 Solid Axle.
    Kit ordered 7/8/2024 - Kit delivered 9/04/2024
  5. Thanks Doc76 thanked for this post
  6. #4
    On a roll Al_C's Avatar
    Wheaton, IL
    Here's an alternative: Rustoleum engine paint. I used that on my IRS center section. Since many people call that part the "pumpkin", I painted mine orange. Since I painted it prior to installation, I sprayed it on. I needed something a bit whimsical. The paint is going strong after 5 years on the road.
  7. Thanks Doc76 thanked for this post
  8. #5
    Mar 2021
    SE WI Kettle Moraine
    I find POR primer has good impact resistance and brushes out without brush marks. It is slow cure. On cast surfaces and machined edges, the primer fish-eyes and pulls away from the sharp edges. That requires a recoat, usually after the primer sets, and before it is completely cured. PIA
    jim
  9. Thanks Doc76 thanked for this post
  10. #6
    Dec 2017
    Southern Ontario/Cape Coral FL
    I use Amor Coat. Shines better than rust o leum and brush strokes level out. Also readily available at Canadian Tire and way cheaper than POR15.
    Higgy
    MK4 #11173 picked up 01/20/25
    MK4 #11012 picked up 04/16/24
  11. Thanks Doc76 thanked for this post
  12. #7
    O'Fallon, MO
    ANY black paint you find. Nothing special needed
  13. #8
    Rustileum has worked well for me.
  14. Thanks Doc76 thanked for this post
    Likes StangRacer liked this post
  15. #9
    Feb 2020
    Virginia
    Another vote for Rustoleum. I used the satin black to paint the k-member, front a-arms, rear end, and other small parts on a foxbody Mustang I built over 20 years ago. Those components still look good today...
  16. Thanks Doc76 thanked for this post
  17. #10
    Rustoleum Self Etching primer and Rustoleum Appliance Epoxy (in spite of the name it is a standard rattle can 1 part paint that matches FFR frame powder coat well).
  18. Thanks Doc76 thanked for this post
  19. #11
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    I wire-wheeled the hell out of my 8.8 axle, then put down Rustoleum primer, then satin black Rustoleum.
    Matt
    My build thread here
  20. Thanks Doc76 thanked for this post
  21. #12
    Rustoleum self etching primer & Black engine paint.
    Kevin
    MKIV #8234
  22. Thanks Doc76 thanked for this post
  23. #13
    Jul 2024
    BC, Canada
    Ended up with powder coat.
    Locally having sprayed in a good quality epoxy was same price as my buddies pc shop. So I opted for pc. Over the years I haven’t had real good luck with rattle can paint from a longevity standpoint and given all the work put into this, wanted something that would last.
    I think it turned out pretty good for a rebuild. Boxed the banana bracket. Fab’d a copy of the VPM 3 link brace. All new guts with an 31-spline upgrade. Even found a home for my lateral braces I had kicking around for years
  24. Likes StangRacer liked this post
  25. #14
    Woodstock ,Illinois
    I am a fan of Rustoleum Farm implement paints. Loads of solids in them and cure nice and hard!
  26. Likes Doc76 liked this post
  27. #15
    Jul 2024
    BC, Canada
    Quote Originally Posted by steno View Post
    Have you happened to use it on the fiberglass inners?
    The OB of my car left much of the inners red. Looks kinda janky.
    My local PPG rep suggested that “farm” as an alternative to higher quality paints. I know many guys go the bed liner route but for several reasons, I won’t be going that route.
  28. #16
    Senior Member Nigel Allen's Avatar
    South Australia
    Quote Originally Posted by Doc76 View Post
    Body Schutz?
    Gen1 Coyote / TKO600 / IRS
  29. #17
    May 2018
    Chaska, Minnesota
    Rustoleum also makes a "hammer finish" paint in several colors. The hammer finish is great on cast surfaces and has a hard durable finish without brush marks. It works well on frames, transmissions, and any other cast part.
  30. Likes Doc76 liked this post
  31. #18
    Apr 2023
    boxing the banana bracket was a good move. I folded mine up at the dragstrip with a second gear launch...
  32. Likes Doc76 liked this post
  33. #19
    Jul 2024
    BC, Canada
    Quote Originally Posted by Nigel Allen View Post
    Body Schutz?
    For now I need to stay away from anything rubberized. Just looking for a durable, easy to clean and touchup, black.
    Ill be adding inner liners so also feel the rubberized/bedliner route for me will be redundant.
