Results 1 to 4 of 4
Thread: Era 289 fia
    Husband/father/son mrmustang's Avatar
    Greenville, SC
    Era 289 fia
    ERA-2080---Turn key, fully loaded, factory built in 2002 by ERA. Titled as a 1964 Ford using the ERA issued VIN, Painted white frost pearl, with deep maroon metallic colored stripe with the layout similar to CSX 2173, Correct FIA dash layout, Correct Stewart Warner gauges, Correct switches, Heater/defroster, Wipers, Tonneau cover, Full convertible top with side curtains, Correct 15”wood Cobra steering wheel with ERA optional removable hub, Leather seats on sliders, Leather E-brake handle cover, Leather door panels, 4 point seat belts, full carpet set, Wind-wings, Sun visors, Correct AC pedals, Correct FIA-6 pin knock off wheels with fresh Cooper Cobras, 225/65/15 fronts, 295/50/15 rear, ERA competition rear with outboard brakes , ERA spec’d 4 piston front brakes on 12.3 rotors, ERA Front and rear sway bars, Coil over shocks front and rear, Tremec TKO 5spd with hydraulic clutch and blowproof Lakewood bellhousing, ERA spec HD aluminum radiator with aluminum overflow tank, Oil cooler, Front bumperettes, Full rear bumper, Per documents in build binder-351W stroked to 396, 9:8:1 compression, SCAT steel stroker crankshaft, Eagle HiPo rods, Keith Black-Hypereutic pistons, canton 8 quart road race oil pan, Dual hidden power points under dash, Car cover, Records back to original order from ERA, Fully sorted, turn key, 20+ years old and eligible for export to Canada and elsewhere $75,500 No trades considered.
    Car is located in Greenville, South Carolina
    Serious inquiries only please
    Additional pics on request
    Instead of being part of the problem, be part of a successful solution.
    HOW TO BUY A USED COBRA
    Greenville, SC
    Based on the PM I received this am, some clarification apparently is needed, I don't need to sell it, I'd like to free up some indoor space, which I am now short of, seeing that both the Tiger and the Cobra are of similar setup, after some contemplating, I decided to place the Cobra up for sale instead of the Tiger. I may change my mind and offer the Tiger for sale, but at this point, I'd rather sell the Cobra than the Tiger. Worse comes to worse, I'll sell my Trailex trailer instead and open up enough space to work, and maybe even buy another 2 seater convertible
    Senior Member chmhasy's Avatar
    North CT
    What is the Tiger?
    Greenville, SC
    Quote Originally Posted by chmhasy View Post
    What is the Tiger?
  5. Likes Geoff H liked this post
