On Gen2 with full fenders/running boards you need to use the bottom holes.
Jim
Jim
Lower holes for full fenders and trucks. Upper holes for no fenders or bike fenders. NOTE: If you go with the lower holes there is no going back as you need to cut the top of the rearmost lower control arm mounting bracket to have enough clearance for the steering rack. It's in the build manual. It's a personal choice though if your not using full fenders. More rear tire clearance, although adjustable with the coil overs, and more road to frame, or exhaust, clearance. I chose the lower holes, potholes and speed bumps, to save the cats which are round and hang some what low.
Moving steering shaft over to the right 3 inches to straighten funky angles out and moving brake pedal over to where clutch pedal would be
33 hot rod,383 sbc tri power setup ,700 r4 transmission,gen1 body gen2 chassis
Got my block hugger headers in
Hi LTF, Re: Mounting bolts for Shocks at Front End................
It's best to have the NUT nearest the radiator not the bolt head. When it comes time to change things, you don't want to have to move the radiator to get the bolts out.
Once you put the Fan Shroud and fan in place it gets pretty crowded around those fasteners.
(I learned this from experience!)
Best wishes,
Tom
From building race cars my whole life all bolts go front to back ,it’s a hard habit to break,if nut falls off bolt will not come out with car moving forward
When did you get the grill? Looks good!
Just got it the other day,thank you sir
I got these from Speedway for my '33: https://www.speedwaymotors.com/Speed...ghts,8978.html
Keith HR #894
Sold the tunnel ram, Was gonna put a cross ram on it, ended up getting a Tri Power set up which I’m rebuilding now
IMG_7558.jpg[ATTACH=CONFIG]208969[/ATTACHIMG_7558.jpg
Getting ready to paint the chassis
I had the same idea...
- Peterh226
35 Hot Rod Truck (Ext) Delivered 11/21/24
33 Hot Rod Gen 2 #1134 ~1400 miles
54 Pontiac Star Chief
05 F-150
Beautiful car sir
Got my new rear lower arms,also got ride of all the rubber bushings in the front suspension
Yes sir
Tourque,nice flat curve
Custom ground by my friend at Koury racing engines
Chassis goes for paint next week,then I can drop the heart in
Red loctite
Can’t decide which valve covers I like better with the wire holders
I like the Ball-Milled with the Flamed wire looms. Breaks it up a little....
All most ready
Mmmm.... engine porn!! beautiful!!
Not sure if I have commented on your '33 yet on this site, but our cars are very close, as I am serial # 1337 (you are #1340), I placed my order on 12/31/2022 (you did on 1/12/2023), mine was delivered on 5/29/2023 (yours was delivered on 6/10/2023). On top of that, we chose a similar color too. How did you get a Gen 1 body with a Gen 2 chassis?
Image - 2024-07-13T191548.387.jpegImage - 2024-07-20T175451.949.jpegImage - 2024-10-19T115628.436.jpegIMG_0662.jpg
I bought a gen 1 body off a guy who used work at factory five,and full fenders off Mike here in Massachusetts,your car is beautiful sir
Almost ready to go vroom vroom
Working on rear brakes
