Thanks Thanks:  6
Likes Likes:  4
Results 1 to 19 of 19
Thread: What Oil Pan-347/363
    Jul 2024
    BC, Canada
    What oil pan/pump/pickup to maintain ground clearance is recommended for our Mk4’s?
    Looks like the z2363 I am considering comes with a deep pan.
    Senior Member TBull's Avatar
    Dec 2011
    St. Louis
    I have used the Champ Road race pan on multiple builds with good success. That in tandem with the energy motor mounts.
    FFR #4402 MKII Supercharged 308 445 RWHP Sterling Grey W/ Black Sapphire Stripes, Purchase 8/22/2008 Sold 12/04/2018
    FFR #8249 MK IV "Milano" Kit purchased 10/5/2018 - Graduated with 3.27 IRS, Multiport, Fuel Injected Supercharged 347 Big bore with Coil On Plug running Holley HP engine management, 576 RWHP, 510 Torque
    https://thefactoryfiveforum.com/showthread.php?29980 Milano thread
  3. Thanks Doc76 thanked for this post
    Dec 2021
    Flower Mound TX
    Might as well go with the best, Aviaid 155-55362
    https://aviaid.com/shopsite_sc/store...s_sbf-ss2.html
  5. Thanks Doc76 thanked for this post
  6. #4
    Jul 2024
    BC, Canada
    Certainly nice ones!
    Looks like they’re all front sump. Width wise it’ll work but front sump and drain plug on the front? Not sure if that’s kosher in our Mk4. I think we’re better off rear sump no?
    Have you used this one before in an FFR Mk4?
  7. #5
    Fits just fine.
  8. #6
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by Doc76 View Post
    That's actually a copy of pans that were in the original 427 Cobras. I'm running the 351W version, fits fine.
  9. Thanks Doc76 thanked for this post
  10. #7
    Mk4 is wide open and can go front or rear dump. We have to go rear dump with the Mk5.
  11. Thanks Doc76 thanked for this post
    Likes GoDadGo liked this post
  12. #8
    Like A Chevy Sir Jeffski?
  13. #9
  14. #10
    Dec 2021
    Flower Mound TX
    Now you know you can't put a Chevy engine in a copy of a British sports car. Chevys only go in Ford street rods.
  15. #11
    Jul 2024
    BC, Canada
    Fits just fine.
    Rich do you have this one on your 331?
    Wondering if main caps have to be ground to make this fit the 302 platform as Aviad told me today on the phone.
  16. #12
    Jul 2024
    BC, Canada
    Is there an advantage to one over another?
  17. #13
    Dec 2021
    Flower Mound TX
    I have a 351 so very similar. It will fit a 4 bolt main block as long as main #1 & #5 are 2 bolts like a Dart SHP block. SVO and Iron Eagle blocks have all 4 bolt main caps and these pans will not fit those.
  18. Thanks Doc76 thanked for this post
    Likes Railroad liked this post
  19. #14
    Jul 2024
    BC, Canada
    I’d have to say the Aviaid looks like it has the highest quality of workmanship of any of the pans.
    I do notice is 6qt capacity vs the Champs 8qt
    Any issue with that, say running hotter, increased wear, etc?
  20. #15
    Dec 2021
    Flower Mound TX
    It is very high quality.
    It's 6 quarts plus the filter. This is plenty of oil for a street engine, especially if you run a high performance oil like Driven.
  21. Thanks Doc76 thanked for this post
    Likes Doc76 liked this post
  22. #16
    Jun 2023
    Texas Hill Country
    I changed from a factory Mustang pan to a rear sump Kevko F901 Cobra Kit Car model. I’m happy with the quality and 7+1 capacity. It fixed the oil pressure drop I saw during heavy braking in early go cart drives.
    https://kevkoracing.com/products/par...-pan-rear-sump
    More in my build thread-#86
    https://thefactoryfiveforum.com/show...ating&p=575388
    BUDFIVE
    Complete kit order 8/28/2023
    347 Ford Dyno 10/12/2023
    Kit Delivery 11/28/2023
    First Start 7/4/2024
    Go Cart 8/31/2024
  23. Likes Doc76 liked this post
  24. #17
    Dec 2021
    Flower Mound TX
    Depending on your motor mounts and how your engine sits in the frame that Kevko 7.5" pan could hang slightly below the frame rails, not something you want.
  25. #18
    Salt Lake City, UT
    "What oil pan/pump/pickup to maintain ground clearance is recommended for our Mk4’s? Looks like the z2363 I am considering comes with a deep pan."
    I'm almost certain the front sump pan that comes on the Z2363 crate engine will give enough clearance on a Mk4. I have that oil pan (https://performanceparts.ford.com/part/M-6675-FT302) on the 302 in my Gen 2 Type 65 and it does not hang below the frame rails (I am using Energy Suspension engine mounts). I can't comment on the rear sump version, nor on how effective it is on a track. The price was very steep to buy it separately, but the quality was there, for what that's worth.
  26. #19
    Jul 2024
    BC, Canada
    Quote Originally Posted by Jacob McCrea View Post
    Good to know thanks
    It’s looking like I am more likely to be going 363 Dart SHP with AFR heads. I was under the impression it was cheaper to buy crate which is what turned me onto that z2363 originally, but not so in Western Canada. By the time I land a Z2363 at my local dealer, I’m $24k into that motor (no carb, intake, etc), and that was before the tariffs
    Looks like I can build a Dart 363 with AFR heads for less.
    That’s according to several reputable engine builders.
