Thanks Thanks:  8
Likes Likes:  2
Results 1 to 13 of 13
Thread: Seat Heaters
    Senior Member MaxVmo's Avatar
    May 2023
    Seat Heaters
    Hi all, have decided to install seat heat. Anyone have a favorite?
    BUILD in progress:
    MKIV delivered Sept 2023 BPE 347 Tremec Five Speed
    First start https://m.youtube.com/watch?v=GHb0v2GtFk0
    Woodstock ,Illinois
    From Forte! For ease of installation, I ran 12 volts to the seat location, tucked all the control wiring in the seat and put the switch on the front of the seat bracket. It's easy to get to and doesn't clutter the dash.
  3. Thanks MaxVmo thanked for this post
    Likes Nigel Allen liked this post
    Dublin, OH
    got mine from cobra heat. I think Mike Forte sells them too.
    Easy to install. Just need to figure out your wiring and switch placement.
  5. Thanks MaxVmo thanked for this post
  6. #4
    Dec 2021
    Flower Mound TX
    Forte
  7. Thanks MaxVmo thanked for this post
  8. #5
    Senior Member Rebostar's Avatar
    Jan 2024
    Got mine from Summit, thay are made by Dorman. They come with the switches and relays all pre-wired. Simple installation instructions. The switches have a high and low setting. They look and work great. https://www.summitracing.com/parts/RNB-628-040
  9. Thanks MaxVmo thanked for this post
  10. #6
    Senior Member TTimmy's Avatar
    Sep 2021
    Emmaus, PA
    I used some generic Dorman units. I simply ran power to the seats and installed the switches and other bits into the seat assembly. I did this for both of my builds.
    Here’s what I did… This may help:
    https://thefactoryfiveforum.com/show...l=1#post572026
    Build 1: Type 65 Coupe
    - Album: Coupe Album
    - Delivered: February 24, 2022, Legal: April 20, 2024, Complete: TBD
    Build 2: Mk3 Roadster
    (Acquired as a partially started build)
    - Build Thread: TTimmy’s MK3 Basket Case Build Thread - Album: Mk3 Album
    - Originally Delivered: 2004, Acquired by me: August 2024
  11. Thanks MaxVmo thanked for this post
    Likes steno liked this post
  12. #7
    Senior Member Lidodrip's Avatar
    May 2020
    Yarmouth, Maine
    Warmseats Seat Heaters from Cobraheat - https://cobraheat.3dcartstores.com/W...ater-_p_9.html
  13. Thanks MaxVmo thanked for this post
  14. #8
    May 2023
    Thank you all. I have an unused heater power source wire—thinking of this for power.
    BUILD in progress:
  15. #9
    May 2023
    Quote Originally Posted by Lidodrip View Post
    Picked these up. How did you end up routing the system? I’m at the initial brain blank and stuck on where to route the connectors (through the trans tunnel?). Thanks!
    BUILD in progress:
  16. #10
    Heart of Dixie, Alabama
    Put the disconnects or wiring plugs between the seat and tunnel with some slack. You will thank me, if you ever remove your seats.
  17. Thanks MaxVmo thanked for this post
  18. #11
    May 2023
    Thank you. I think im going to mount the harness behind the dash and cut/splice the seat connectors and run the wires along the bases of the trans tunnel.
    BUILD in progress:
  19. #12
    Senior Member F500guy's Avatar
    Aug 2022
    Portland, Oregon
    Since I had my seat switch dash mounted, so I mounted the relays behind the dash and routed the seat wiring down the side of the transmission tunnel and along the inside corner, I wrapped the wire with a vinyl loom tape for added protection. I left a small cavity along the edge of the heat shield so the wire set pretty flat and covered with carpet so the wiring was pretty well hidden after.Cutoff Carbon Fiber Plate.JPG
    Hope this helps
    MK IV Delivered June 27, 2023 Build Thread-https://thefactoryfiveforum.com/showthread.php?46069-Lance-s-Roadster-Build-Thread-Starting-the-Al-panel-slog
    "Build a Car" They Said "It Will Be Fun "
  20. Thanks MaxVmo thanked for this post
  21. #13
    May 2023
    Thank you—that’s what I will do!
    BUILD in progress:
