Sale of nevr used parts and donor car
IN THE MIDST OF BUILDING OUR MKIII HAVE ACCUMULATED PARTS: '95 MUSTANG GT>> PARTING OUT CAR: 5spd std $375; REAR- ROTOR TO ROTOR $350; ENGINE HARNESS AND BRAIN $250;
INSTRUMENT CLUSTER (BLACK) $100; VERY SEASONED 351W BLOCK W/HEADS (HAVE MAIN BEARING CAPS AND BOLTS, DISTRIB) $100; CLEAN 289 SHORT BLOCK W/PISTONS AND RODS STILL IN (WAS TOLD IT WAS OUT OF A TRUCK) 4125 A BRAND NEW HYDROBOOST UNIT WITH MASTER CYL ATTACHED (NEVER USED! I PURCHASED A DIFFERENT HYD UNIT); NEW GENUINE FORD BELL HOUSING, NEW RAM STEEL 164T FLYWHEEL, NEW McCLEOD CLUTCH ASSEMBLY NEW McCLEOD PRESSURE PLATE (CALL FOR PART #'S FOR APPLICATIONS) NEW GENUINE FORD ENGINE SPACER THANKS ARTNANS351WCOBRA
Reason: PARTS N/A TO THIS SITE OR PRICES TO HIGH
PM sent re: hydroboost unit
do you still have the bell housing, and will it fit a TREMEC 3550?
