Kai-Rod's #236 Build Page
I have seen quite a few really nice build pages which helped me a lot with my build. I am now starting my own build page with this photo taken at Hammink Performance in the Netherlands the day that I picked my kit up. I am working with a MAC computer and still have not figured it out. So things will take a while. I have done a few things different on my Rod and hope to be able to show you some of that here soon.
Kai
Hanau/Germany
Rides & Projects: 54 F100 347SBF/Auto; 65 Galaxie FB 446FE/5-Speed; 67 Mustang Convertible 306SBF/Auto; 07 Mustang GT Convertible 4.6 3V/Auto; #236 FFR Hot Rod 4.6 2V/5-Speed
Thanks for sharing the pic! Jan and Freek at Hammink Performance are great guys. Can't wait to see more of your build. Good luck!
Dave Lindsey
FFR's Mad Dog
33 Hot Rod Builder
Kai, great to see you here man. I just exchanged some messages with Freek a few days ago. Keep the pics coming and we hope to see some pics from HP too.
Then it was time to install the front and rear suspension. We also added some posters and other stuff to the walls.
The rear end is from a 2003 Mustang GT. Could not believe how rusty and dirty it was.
... more to come.
Kai
Hanau/Germany
That's my engine and tranny combo out of a 2003 Mustang GT which some GI stationed in Germany rolled down a hill when enjoying the German country roads.
This is the first roll out. Needed to turn the car around in order to install the engine.
The wheels are Italian made EtaBeta in size 20x9" up front and 20x10" in the rear. They are left overs from our 07 Mustang. I plan to get smaller ones for the front, but for now I am using what I have.
OK. Time to go to work. More to come over the weekend.
Kai
Hanau/Germany
33 Hot Rod Builder
We had first planned to use different reservoirs for the brakes, but then decided to mount the stock ones. Everything can be mounted pretty easily.
Also in the picture is my idea about reducing the fire wall flex. Quite simple. Just an aluminum bar. Let's if this works.
... more to come.
Kai
Hanau/Germany
This photo was taken in November 10. Just before the snow hit. This is what I would see when I look out of my bedroom window when the barn door is open.
Kai
Hanau/Germany
Here is the heater. We have used the one that FFR offers for the Roadster. The whole things needs to go behind the dash (different to the Roadster where half sits in the engine compartment). I have made my own mounts. The fan sucks the air from the engine compartment thru this neat little home made billet grill and the 3" flex hose.
Kai
Hanau/Germany
I decided to go the The Detail Zone Telorvek Panel route for my engine wiring. First looked at the Wire Diet, but since I did not have a complete original wiring loom and also had some damaged parts I decided against it.
Here I am building a box for the panel to put into the trunk.
I have two holes each side with grommets (not yet installed here) in the left and right panels.
And that is how it sits in the trunk. I have again two holes each side with grommets in the trunk side panels.
Kai
Hanau/Germany
Done. Now we are current. These photos were taken today.
See the mini dashboard with just the ignition switch ?
Here as close look. I wired the starter as well as the battery cable, turned the key and the engine turned over. Wow. The first small part of the electrical system is working.
OMG. This is still a major chaos. Plan is to attach all cables, run the engine and the re-do the whole wiring to make it look good.
... now my thread is current. Good night !
Kai
Hanau/Germany
Kai - it's looking great!! Nice to see all of the details of your progress, particularly w/respect to getting it on the street in Germany.
Beste Gruesse aus Wareham,
Jason @ FFR
We just got back from two great weeks in the US. Flew to LAX, drove to Las Vegas, spent three days at the NASCAR event (Ford won with Carl Edwards - Great !), took an RV and drove to Phoenix for three days at the Goodguys event in Scottsdale, took the RV back to LA and spent the two last days right on the beach in Huntington Beach, our favorite town.
I bought the correct MAF for my engine, completed the provisional wiring, attached the battery, turned the key and it fired right up and idled like a new car. I started it a couple of times and let it run just a few seconds as I have no water in it. I also have no gauges whatsoever and have not clue if I have oil pressure or anything. Now I will educate me a little bit about the SCT Programmer I have got to read out te failure codes.
Here's another photo of the completed chaos called engine wiring. Plan is to add water and let it run a little bit before I remove all the wiring and start all over again making it look good.
What a great day !!!
Kai
Hanau/Germany
Thanks for posting all of the progress photo's. It looks like your build is comming along nicely.
Doug
Thanx Doug ... and also Thanx Jason .... it is always rewarding to get a thumbs up from you guys.
Now the fun starts (and I mean it) to tidy the cables. Hope to get this done over the next week or so.
Kai
Hanau/Germany
Great build! Sounds like you had a fun trip too.
33 Hot Rod Builder
I just got around to looking at the whole thread. Wow, some very creative solutions. Keep the pics coming it looks awesome.
Kai-Rod
Fun build! I do not envy you the task of getting the thing road inspected though...
Maybe it's a bit late for this, but I thought this article was a brilliant way of creating a wiring harness. Basically use some wire or vacuum hose to determine the routing and length of your harness, then attach that to pegboard. Use the wire or hose as a guide for your actual wires, and use the pegboard to keep it all coherent as you go along.
Good luck!
OK. Now all the wiring is removed and I just removed the complete exhaust. See all the parts in below photo. All parts will be ceramic coated. I will also have the bottom of the floor pans and the trunk panel.
Kai
Hanau/Germany
Thanks for the updates. It's an interesting build. I am following it from Chicago, IL.
Spring is arriving and there was a lot to do other than working on the car. Changed the tires on the 07 Mustang. Yes, we have real snow tires mounted to the original 18" wheels. Now we are rolling on the 20" American Racings wrapped in Dunlops.
I did drill all the aluminum floor panels and now they are ready for ceramic coating on the under side. Hope this will help to keep the heat created by the cats away from my legs and butt.
Next will be there wiring. Need to do some additions to my trunk mounted engine control box.
Kai
Hanau/Germany
Thanks Kai, This is a great tutorial you are creating. We've just finished melting the most recent snow here in Wisconsin, so my car is still hibernating. I put the battery charger on it yesterday and now am awaiting a really good April Shower to rinse the residual salt off the roads so that #007 can come out and play. I have a bit over 5000 km on my car so far. You're going to enjoy the car once finished and ready for the autobahn.
Best of luck,
Tom
30 Old School BMW V12 powered Ford Coupe of a friend visited yesterday. Very cool ride and all home made with a million of cool details.
Kai
Hanau/Germany
Very cool Kai, thanks for sharing your pics and build with us!
Keep up the good work!
