Results 1 to 9 of 9
Thread: Body Split
    Member StromSpeed's Avatar
    Jan 2012
    Body Split
    I have heard that some Challenge car owners are splitting the body at the doors, to create front/back sections. I assume this is for much better serviceability. But are there any other pros/cons in doing this? For those who have done it, are there any other mods needed to secure each section? Special coverups, fasteners, etc?
    I'm building a Challenge car myself and this extra access down the road is going to really help, but I wanted to ask the pros here before I grab a saw.
    Kirkland, WA
    Mine is split about mid point in door. Did not use the factory body mounts for side, added an extra mount across the lower part of body where it was split, use 4 button head bolts (4 mount points) on front half and 4 button head bolts (4 mount points) on back half of of body. Body is still somewhat of a pain to remove but it is handy, have to make sure all your wires (head light, tail light, trunk wires,etc) are quick connect and still takes 1.5 people to remove/replace either front or back of body. Maybe if I had it to do over I would do the split but make the front a flip top to have more access
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Nashua, NH
    I cut the body back in 2007 and am glad I did it. Used a 1/4" piece of aluminum that I tapped 2 holes in (one hole for back part of body, other hole for front part of body) and use that plate on the back side of the body to connect the pieces below the doors.
    Make sure to secure the top of the body so it has no way to move back and pinch your fingers between the back of the steering wheel and the body.
    body cut middle part of doors.
    http://johngeorgeracing.com
    Apex, NC
    Mine is basically split at the same place as John's. It makes working on the vehicle 100% easier.
    2012 NASA-SE FFR Champion
    2011 NASA-SE FFR Champion
    Race page - http://www.mh-motorsports.com/race.shtml
    Team Facebook page - http://www.facebook.com/pages/MH-Mot...s/264814350042
    Mark Dougherty's Avatar
    Hershey PA
    yep
    i split them right at the 1 1/2 tube behind the body
    The traveling Builder
    717-773-5624
    Jan 2012
    Awesome, thanks everyone for the info!
    Senior Member dallas_'s Avatar
    Dallas, TX
    Would they allow a tilt front?
    FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
    SL-C, LS3 525, Mendeola SDR5,
    Apex, NC
    In the series a tilt front is not allow but there are a few out there with them.
    Kirkland, WA
    Here is my split
    Tony Nadalin
