My son found this picture, and expressed his opinion that we should route the tailpipes out the center. If given the option how will you route your tailpipes?pagani-zonda-03.jpg
That is sexy! I can see some aftermarket potential in a system like that.
Get Someone to weld you a custom one.
I would want mine out the center as well, With the tranny right there the exhaust will either be high center or low center. Depends on how the final body looks and fits.
Probably work out high centre, the end of the gearbox will be low centre. Same set up in my v-storm below
B33fy, what kind of car is that?
Subaru engined exoskeleton car 3 seater, there's two cars in the states currently.
seeing that v-storm makes me have second thoughts! thanks b33fy, haven't even ordered yet and i'm ready to cheat on the 818!
That thing is sexy. I'm really hoping the 818 body will be gorgeous. Even if it's minimalist, it'll have to compete for my affection with the KTM X-Bow.
As for exhaust the Mp4-12c exhaust is still top contender for most gorgeous exhaust:
