I've been slowly gathering up dry sump system parts for a while and I'm ready for a pan. I called ARE a few weeks ago and inquired about a group buy. With three units ordered they are offering about a 12.5% discount. I specifically inquired about a group buy on their Ultra Shallow pan #1009 but I would guess that other pans would qualify as well if you wanted to go with a different one. If you are intersted, let me know, they stock the pans, fittings and timing chains so if I can get two more people to commit, it should happen fast. I'd like to have a pan in the next month or two.
Here's a link to their LS pans:
http://www.drysump.com/corvpan1.htm
There is tons of general info out there on dry sump systems so I'll just concentrate on GTM specifics here.
Some things I have learned on this dry sump journey:
If you don't want to spend a whole bunch of time on modifications, go with an external scavenge pump and keep the LS internal pump for the pressure side. ARE calls this a Stage I System. http://www.drysump.com/ls1.htm This system will simplify plumbing and probably not require any frame mods. The pump mounts on a modified A/C bracket and uses an ATI damper.
Their Stage II system adds the pressure pump for an external 3-stage setup and I think could get by without frame mods, just a bit more plumbing.
Once you go to a pump with four or more stages it gets a bit more involved. Frame mods come into play as the pump is longer and the drive needs to be forward of the damper on a mandrel (unless you go with a front motor plate and inverted exhaust, ie- Crash). This gets into the passenger side tunnel diagonal and some of the ports on the bottom of the pump end up right on top of the crossmember under the engine. The crossmember may not be an issue if you don't lower the engine but If you're looking at a serious 4-5 stage system, you're probably planning on making some serious g's and you're going to want the biggest mass in the car as low as possible.
I'll be removing my engine/trans soon to get at all the frame mods I want to do and mounting the pump, pan and plumbing to the engine. I also need to mill the bottom off the Kennedy adapter as the low profile pan does not tie into it and I want to get the engine as low as practical. I'll post more later on specifics of the system, there are so many.
Mark
