Results 1 to 3 of 3
Thread: Looking for 2012 lower radiator hose part #
    Senior Member MPTech's Avatar
    St. Louis, MO
    I want the "S" bend hose to attach to the lower radiator fitting and avoid the chassis tie-down.
    I tried NAPA and Autozone, no luck. Also tried google, but couldn't find a listing.
    Can't help with a part number but just as an FYI it is possible to make that bend using the corrugated tubing and supplied coupler.
    Whichever method you choose I think I'd still plan to secure the hose in the center (the X member works well). It's a pretty long section that will get kind of heavy when full of coolant and which can jostle about when the car is moving if it's not stabilized. Two cents...
    St. Louis, MO
    Thanks Jeff !
    Mine makes the bend, but it does touch the tie-down just a bit. I've tried rebending but it doesn't allow me enough clearance to feel comfortable.
    If I move the bottom of the radiator forward (I fab'd an adjustable radiator support), it will clear, but then the radiator is not setting at the angle FFR suggests.
    btw, I am planning to install a support attached to the x-member. I bought a clamp/hanger from the hardware store, but not sure if I'm going to use it or by the Breeze clamp.
