Results 1 to 11 of 11
Thread: Need some knowledge
    Stationed at Ft Hood, Tx. Currently deployed.
    Need some knowledge
    Need some help. I'm trying to plan the car out that I want to build when I get back to the states in a few months. I want to drop in a 351 Winsor coupled with a T-56 trans. What kind of bellhousing do I need to get to make the fit and who has any reccomendations on where I can get the bellhousing?
    Call Mike and/or Steve.
    http://www.fortesparts.com/
    Junior Member peffem's Avatar
    Maryland Eastern Shore
    Check out this Thread post #18. Maybe you want to consider the TKO600-R. THANKS FOR THE SERVICE
    Here the link I forgot to past in: http://thefactoryfiveforum.com/showt...r-the-25-Hours
    Inn Keeper, Maria's Love Point Bed & Breakfast, Stevensville, MD 21666
    Trick Tool Maker, Super Moderator Hankl's Avatar
    Northern CA
    I know some people like the fact that they can say that they have six speeds, but in these cars it a waste. Not only in space, but also money wise.
    You'll only be able to use a IRS with the T-56 configuration, as the overall length of the transmission does not allow for a drive shaft on any length that could articulate with a live axle.
    Hank
    “If you didn’t have enough time to do it right the first time. How come you always have time to go back and do it again?” FFR1000186CP
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    Super Moderator
    Richmond, ca.
    Which ever trans you end upwith I highly recommend the Quicktime scattershield. you can see it at the Fortes link above.
    Fort Lauderdale Fl.
    Your going to have hood clearance issues using a 351 In a couPe, it's taller ...hTH. Steven
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
    Coupe Modifier RonSchofield's Avatar
    Halifax, Nova Scotia, Canada
    +1 with Russ on the Quicktime.
    +1 with Steven with the height problem with the 351.
    Type 65 Coupe Builder / Coupe Parts Vendor
    Websites:
    myCoupe Build
    F5Registry
    Junior Member Bill Shaw's Avatar
    Quote Originally Posted by riptide motorsport View Post
    Doesn't the new Coupe nose give you more engine room?
    Green Bay WI
    302 based 347 stroker is superior to a 351; lighter, less friction in the mains and more compact. TKO 500 with a scatter shield or and old SROD bell housing. Let the Good times Roll!
    Northern CA
    Quote Originally Posted by Bill Shaw View Post
    No, it was initially rumored to have more room, but that was incorrect.
    Hank
    Hank,
    Jim Schenk answered the "hood height" question ... I was wrong, the next Gen hood has not been changed. However, that was a running change was made 3-4 years ago, giving about 1 1/2" more hood clearance at the bubble. So the long answer is yes, there is more hood clearance on the newer kits. Sorry about the confusion.
