This is a vintage racer that is in good running condition. GoPro video available from High Planes Raceway recently... The car was constructed by a Nascar truck fabricator and was raced since in SCCA GT-2. This is a 3/4 tube fiberglass body racecar which has a new motor with less than 3 hours running time, 2.8L block, 2.4L head, Cannon intake, 3 - 40mm Webers, MSD electronic ignition, new low weight starter, new alternator, new 1lb fuel pump with stainless shielded lines, mousetrap oilpan, removable steering wheel, complete fire system, ATP front brakes/vented rotors. The engine was built by a Datson engine specialist out of Thompson CT and makes 275 to 300hp.
This racecar would make for an inexpensive track car or could be run in SCCA, NASA, COM, SVRA, VSCCA, VRG. or Drifting.
Please call Shawn at 303-656-0213 with any interest.
