dreabrown
dreabrown,
I did use the Russell Push-on EFI quick disconnect male fitting with a AN cap and it seams to work just fine. I first tried rubber caps but the pump blew a hole in them twice so I went the extra cost and went with the Russell fittings. If you go with these fittings be sure to use a little lock tight on the cap.
